PT Wood End Treatment - No One Local Carries It, Alternatives? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-18-2012, 11:22 PM   #1
Rewards Points: 43
PT Wood end treatment - no one local carries it, alternatives?
Been going crazy trying to find a lumber yard or building supply company that carries something like the copper green wood preservative. No one has it, or has even heard of it!!
I live over in central jersey, middlesex county area and so far no luck.
I'm curious if there are alternatives that can be used and just as good, something like a normal wood sealer, or an oil for hardwoods like IPE? Any other ideas?
Thanks!!!!
Quicksmoke is offline   Reply With Quote
Old 04-18-2012, 11:44 PM   #2
Rewards Points: 626
Jassco # 9 brown or green will do it for you.
Nailbags is offline   Reply With Quote
Old 04-18-2012, 11:53 PM   #3
Rewards Points: 14,010
That is it your really trying to do?
Differant woods and differant places it's going to be used would be treated differantly.
IPE does not even really need a sealer.
No form of surface apply treatment is going to work as well as real pressure treated wood. The key is it's pressure treated, which means it's forced deeper into the wood not just laying on the surface.
Old 04-19-2012, 09:21 AM   #4
Rewards Points: 43
Preservative may be forced into the wood, but it doesn't get forced through 100% of the board. Need to treat the cut ends where the preservative didn't penetrate. The area I'm in is notorious for termites, so I need to take every precaution I can to try and protect the PT wood.
The Following User Says Thank You to Quicksmoke For This Useful Post:
woodworkbykirk (04-19-2012)
Old 04-19-2012, 11:13 AM   #5
Willing to listen
Rewards Points: 223
Black Flag termin 8 copper green at Lowes in my area.
Done That is offline   Reply With Quote
Old 04-19-2012, 11:42 AM   #6
Rewards Points: 790
could paint on water proofing tar (the kind that is painted on foundation)....or wrap the posts in something like "ice and water barrier" which is applied on roofing applications.
Not sure why you would need to do all of this?
cibula11 is offline   Reply With Quote
Old 04-19-2012, 01:52 PM   #7
cortell's Avatar
Rewards Points: 504
Without treating the end cuts of PT lumber for some lumber species (see below), the cut area is vulnerable to termites and rot. The OP is simply trying to find the right product.
Tar or ice-and-water shield on an end cut that's going to be visible is going to look quite ugly. Even if it's not visible, tar is messy, and a moisture membrane is both cumbersome and relatively expensive.
That said, most PT lumber are of species that do not require field treatment. According to American Wood-Preservers' Standard M4-06:
6.2 Lumber and timbers Lumber and timbers with a nominal thickness of 150 mm (6 inches) or less which are used in above ground applications and are of a sapwood species such as southern, red or ponderosa pine, generally do not require field treatment to provide a good service life. However, material with narrow sapwood faces or having heavy heartwood in cross section should be field treated in accordance with Section 6.1 when cut or drilled. When lumber is from a heartwood species such as hem-fir, larch or Douglasfir, it should be field treated in accordance with Section 6.1.
cortell is offline   Reply With Quote
Old 04-19-2012, 02:09 PM   #8
Rewards Points: 790
Sorry, must have missed the OP stating it was going to be seen. I guess I just can't picture how a cut end of a 4x4 would be seen, and also exposed to so much moisture as to have to treat it a second time???
Old 04-19-2012, 02:20 PM   #9
cortell's Avatar
Rewards Points: 504
Where does he say it's a 4x4? Anyway, it's mostly a moot point. The vast majority of PT lumber is pine which doesn't need end cuts treated. And if he does need it, another poster pointed him to a suitable product.
Old 04-19-2012, 07:03 PM   #10
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
your not the only one trying to find "END CUT" i use to be able to buy it and pentox both at my local lumberyards plus 2 of the 3 big box.. just in the last month the lumber yard no longer has it. nor does the two big box.. suddenly though home depot who we dont buy through has it..
woodworkbykirk is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Staining "PT" wood rossfingal Painting 6 10-03-2011 07:11 PM
Alternatives to using wood structural members in a brick building vvzz Building & Construction 5 05-03-2011 06:52 PM
Wood floor drying, build raised platform? Puzzles Flooring 3 05-03-2011 03:23 PM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 04:16 PM
