PT Studs Or Metal - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2013, 10:29 PM   #1
PT Studs or Metal
I'd like to hear everyone opinion on framing options for a finished basement. PT wood, bluwood or metal studs??
My application will be for a 75% below grade, concrete block wall, 1956 cape in nj. I plan to use metal studs. Currently I have a minor seepage issue I am trying to address prior to framing. Hopefully I will be succesful, however even the dryest basements will have moisture due to condensation.
Stcrosby is offline   Reply With Quote
Old 07-23-2013, 12:48 AM   #2
concretemasonry's Avatar
Rewards Points: 2,572
Even though steel studs are galvanized, they are not corrosion proof. Wherever there is a screw connection or a rivet, the hole exposes the ungalvanized area that never dries out, so rust is a concern. Many designers are very concerned when specifying for areas with potential moisture or with condensation on the stud surfaces.
Dick
concretemasonry is online now   Reply With Quote
Old 07-23-2013, 07:22 AM   #3
Rewards Points: 12,914
Got to get that moisture issue under control first.
90% of the work needs to be done outside not inside to prevent the water from coming in.
Once that fixed a pressure treated bottom plate and regular studs will be fine.
Do not install any untreated wood in direct contact with the concrete.
Old 07-23-2013, 07:32 AM   #4
ccarlisle's Avatar
In your case, 'Bluwood' hands-down...only trouble is: availability.
Even though Mike Holmes used it in New Orleans, I am still not sure you guys can buy it.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 07-23-2013, 08:37 AM   #5
AHH, SPANS!!!
Rewards Points: 1,166
be careful with that stuff, I've been around people who got sick from it including myself...
hand drive is offline   Reply With Quote
Old 07-26-2013, 09:21 PM   #6
Thanks. Ive actually never seen bluwood sold anywhere here in NJ.
Im still undecided whether to use PT studs or metal for the basement framing
Pros/Cons;
Metal will eventually corrode but will never feed mold. (even with my water issue resolved, there will always be some moisture due to condensation)
PT Suds will eventually break down and be vulnerable to mold growth
Eventually is the big unknown?????
Old 07-28-2013, 02:58 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,036
PT wood will twist and warp as it dries, not a good surface for drywall. Also the chemical preservative will eat up the screws or nails used to hang the drywall. Do not use it.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
joecaption (08-29-2013)
Old 07-28-2013, 07:29 PM   #8
Registered User
Rewards Points: 4,944
SS or wood studs are fine if the foamboard on concrete walls is thick enough to prevent cavity condensation. Pt studs not required, #7 , pt plate if using Thermax foam strips under it for thermal/air/capillary break- #3; http://publicecodes.cyberregs.com/ic...9_3_sec017.htm
Gary
PS- wouldn't hurt to seal screw fasteners of SS, as Dick said.
Old 08-29-2013, 07:43 PM   #9
Rewards Points: 29
On the outside walls I would use wood (not PT). Being in NJ conductive heat loss through metal studs during the cold months must be considered. everywhere else I would use metal....for all the already know reasons....weight, versatility, dimensionally correct.
liljohnny is offline   Reply With Quote
Old 08-29-2013, 07:53 PM   #10
Framing Contractor
Rewards Points: 100
I have never seen basement studs rotted away. If you have a moisture issue, it wont matter what studs you use. Treated bottom plate, spf studs. The studs should not have contact with the block walls anyway. Water would need to rise up 1 1/2 inches to ever contact the studs.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
kwikfishron (08-29-2013)
Old 08-29-2013, 10:34 PM   #11
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,012
teh bottom plate will soak up water and then up into the studs.. end grain will soak up water quicker. no matter what though make sure your using sil gasket under the plate
woodworkbykirk is offline   Reply With Quote
How to add blocking w/ steel or metal studs bergerdude Building & Construction 12 04-30-2013 10:59 AM
Felt paper on concrete floor and metal studs Crani123 Kitchen & Bath Remodeling 1 08-06-2012 08:51 AM
STRONG Anchor to metal studs smouton1 Building & Construction 7 07-01-2012 10:25 AM
metal studs on drywall patg Drywall & Plaster 4 12-29-2011 02:56 AM
insulating metal studs - help maintenance Building & Construction 2 08-05-2005 05:31 PM
