PT Posts For Beam Support - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-25-2011, 08:01 PM   #1
I ask the impossible!
Rewards Points: 704
PT posts for beam support
Let me just double check something real quick please... I can get 6x6 PT posts that are rated for ground contact at $19.97 for an 8' length or not rated for ground contact at $15.97. These are going into galvanized simpson brackets set into concrete at the bottom. The top of the concrete footings are level with the ground. (And will have drainage put in on 3 sides)
Am I correct in assuming I don't need the ground contact and can go with the less expensive post?
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 03-25-2011, 08:08 PM   #2
Rewards Points: 5,336
The brackets should keep the wood off the ground. How many posts are we dealing with where $4.00 per post is an issue?
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
tcleve4911 (03-26-2011)
Old 03-25-2011, 08:44 PM   #3
Rewards Points: 704
It's the difference between starting this weekend or putting it off to the next weekend. There are 7 posts per beam and I'm getting 3 posts per 8' board. So I'd need 3 to build up the one beam I'm planning to build this weekend. The extra $12 is enough to put me over budget. I'm also getting the 2x10's for the beam and a box of framing nails.
Old 03-26-2011, 06:15 AM   #4
DIY staff
Rewards Points: 7,174
Are the cheap ones structural wood or are those actually landscape timbers?
Old 03-26-2011, 06:39 AM   #5
Rewards Points: 704
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
As far as I can tell the non-ground contact is treated with ACQ and the ground contact is treated with CA. Both indicate use for decks.
Lowes only has 1 6x6x8 listed at $19.95 and it's treated with ACQ and rated for ground contact.
Old 03-26-2011, 07:51 AM   #6
You need special fasteners for pressure treated wood. Hot dipped galvanized or stainless steel. The wood will "eat" regular nails in a year or so.
Ron
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 07:03 PM
What fill around mudroom support posts? ramatsu Remodeling 1 08-13-2009 11:53 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Replacing covered porch support posts yousah Remodeling 4 09-30-2007 12:15 PM
Support posts for 12' high deck hotchkiss Remodeling 3 09-05-2007 06:32 PM
