PT Lumber Weight - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-24-2010, 02:47 PM   #1
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
PT lumber weight
Does anyone have a chart or know how much PT wood weights per cubic foot? I heard a number around .6 - 1lbs per cubic foot?
Trying to see how much wood i can place on my trailer for a 3 hour drive. thanks
ryanh is offline   Reply With Quote
Old 08-24-2010, 03:21 PM   #2
kwikfishron's Avatar
Rewards Points: 596
That number varies greatly.
You’re better off calling your supplier with that question.
kwikfishron is online now   Reply With Quote
Old 08-24-2010, 04:56 PM   #3
I saw the same cite; it's a misprint. More than 35 PCF is more likely. Fiberglass insulation density is 1.6 PCF.
If you have a scrap of moist PT wood, weigh and measure it. 1728 cu. in. = cu. ft.
Old 08-24-2010, 04:57 PM   #4
Civil Engineer
Rewards Points: 4,782
PT is typically around the density of hardwood. Dry oak comes in at about 50 lbs/cubic foot, wet oak at around 65 pcf, and PT varies from 40 to 70 pcf depending on the amount of preservative in the wood, and the moisture content of the wood. But no way is any wood close to the figures you quoted.
Daniel Holzman is online now   Reply With Quote
Old 08-24-2010, 08:51 PM   #5
Registered User
Rewards Points: 5,516
Be sure to use a tarp for the sun or the top row will be for bean poles.......
Be safe, Gary
Old 08-24-2010, 11:26 PM   #6
Rewards Points: 1,092
Treated wood seems to vary enormously within one stack. I have picked up 2-by's that weigh at least 50% more than the one before it. I could not see how one got wet and the others did not, as they were all in the same banded bundle. I'd load conservatively. j
nominal lumber weight per foot alaus24 General DIY Discussions 4 04-01-2010 09:48 PM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 08:45 PM
Scissor Lift - How Much Weight??? JackOfAllTrades Building & Construction 9 09-08-2008 05:57 AM
Raised garden bed using PT lumber rjniles Landscaping & Lawn Care 12 06-24-2008 09:14 PM
Concern about beadboard weight dphardy Carpentry 4 10-12-2007 02:44 PM
