Old 09-05-2012, 01:08 PM   #1
PT beams warp or twist off posts?
i can post pics tomorrow:
ten year old deck. 4X4 PT posts, double 2X12 PT beams on posts, PT joists on beams. decking and rails are Trex.
the beams span about 20 feet on 3 posts. (3 sets of beams) several of the beams over the years are "twisting" off their posts. I say twist because the top of the beams that are toe nailed into the joists sitting on top of them have not moved, its like the bottom of the double beam wants to "slide" off the post. they've "twisted/curled" about 3/4 of inch off the posts. The posts are still vertical its just bending the aluminum "clip" off the top of the post.
Is it normal for a 20 foot span of double 2X12 (NOTE: its not one 20 foot piece of 2X12, they were 12 footers nailed together, staggered to make 20 feet long) to warp twist?
So either 1) the wood is twisting/warping naturally. or 2) there is frost heave is lifting the deck in some parts and "pulling/shifting" the beams off the posts. (yes i know proper footings should not allow frost heave, but i'm troubleshooting anything that would make beams curl off their posts)
Sorry i do not have a picture now..
windowguy is offline   Reply With Quote
Old 09-05-2012, 01:33 PM   #2
are your beams attached to posts via post caps or just toe nailed in?
allthumbsdiy is offline   Reply With Quote
Old 09-05-2012, 02:05 PM   #3
Get a couple 2.5 foot 2 x 4's and place one one each side of the 4 x 4's and up the 2 x 12's...bolt with 4 galvanized bolts washers and nuts....the bolts should be about 8 inches long
JonM is offline   Reply With Quote
Old 09-05-2012, 02:48 PM   #4
NOT toe nailed in. its just that flimsy cap. looks like a simpson cap but even flimsier.. its just bending that cap right off.
is it that simple? could this have been avoided if the beam was nailed to the post? i think the builder just figured gravity was good enough.
i think i can jack the deck up to take the weight off, wedge a 2X4 against the bottom of the beam (using the adjacent concrete pillar) and smush it back under, then nail off.
I can do that, but i wanted to figure out the source of the problem first.
Old 09-05-2012, 07:12 PM   #5
No, I was not advocating the toe nailing method at all (I've always used Simpson BCS post caps and H1 hurricane connectors for the beam-to-joist connections in my decks).
As far as assembled beams twisting, I guess anything is possible, though I've seen more bowing beams (curving in one direction) in my old decks.
What type of soil is under your deck? Is it pitched to direct water away below? I read that if you have a clay-like soil on the surface, it can possibly cause frequent lateral ice heaving.
Old 09-06-2012, 08:24 AM   #6
GBrackins's Avatar
I may have a solution, but want to wait until I see the photos ....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
How to replace posts before concrete is poured rosco Building & Construction 31 05-07-2010 03:54 AM
Deck Guard posts on top of deck posts -how? davis_mc Carpentry 1 04-18-2010 08:42 PM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 03:55 PM
Steel beams and Posts dhenrycpa Building & Construction 21 01-01-2007 07:52 PM
Installation of pergola posts HDelahay Landscaping & Lawn Care 13 10-11-2006 07:46 AM
