Protective Sill Cover - What Is It??? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-03-2010, 09:24 AM   #1
Protective Sill Cover - What is it???
Does anyone know what a protective sill cover is? I am looking at purchasing Jeld Wen exterior doors for my new home addition and one of the options is a "protective sill cover." The problem is, the door is $496 and the cost to add on the protective sill cover is $252... half the cost of the door. The folks at HD had no idea what it was, but I cannot figure out if it is an expensive scam, like undercoating on a car, or something that could really be important.
Any ideas???
stubits is offline   Reply With Quote
Old 04-03-2010, 09:31 AM   #2
only time i used protective sill covers was in new construction to protect sills from traffic during building. they were plastic and a couple of dollars and disposable. sounds hinky to me, how would you adjust the sill?
The older I get the better I was
Old 04-03-2010, 11:05 AM   #3
TPolk- That's my thinking, really, but wanted to avoid making a big mistake. It seems like too big of an upcharge not to take seriously, but it just didn't make any sense.
Thanks!
Old 04-03-2010, 07:52 PM   #4
remodeling pro
Originally Posted by stubits View Post
Does anyone know what a protective sill cover is? The problem is, the door is $496 and the cost to add on the protective sill cover is $252... half the cost of the door. .
Any ideas???
Someone is missing a decimal point in the price sheet. This is just a moulded piece of plastic that is snapped over the aluminum sill to protect from wear and tear during construction. Most manufacturers ship them installed as a matter of course, without having to be special ordered, definately not a $200 plus item.
At end of job, you pull them off, and the sill is unscratched and not full of paint splatter.
troubleseeker is offline   Reply With Quote
Old 04-04-2010, 06:44 AM   #5
Thanks guys! The guy at HD or Lowes, not sure which, used some Jeld Wen design software, but it must have been wrong.
So, the actual price, $496 for a 36" half light steel door with side light seems about right? Even if $252 for the protective sill plate is off?
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 08:08 PM
Replacing Termite Damaged Sill, Joists, and Girders bd_dc Building & Construction 0 02-01-2010 11:21 PM
How short can sill plate pieces be ? tuckerz Building & Construction 2 10-04-2009 03:41 PM
Door Sill Flashing Pondo13 Building & Construction 1 08-19-2009 06:15 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
