Protection For PT Ledger On The Side Of A Shed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 02:30 PM   #1
Rewards Points: 1,062
Question
protection for PT ledger on the side of a shed
i would like to attach a 2x6 horizontal ledger on the side of my shed for hooks for hanging heavier items (e.g. i have kayaks etc.) that i would not feel comfortable having suspended just on something that goes through the siding. i would attach it before siding and right on top of the sheathing or perhaps the housewrap and would go a foot or a little more under the soffit so it wouldn't be exposed to much of h2o.
Q1: do i still need to protect the upside of the ledger with asphalt membrane and aluminum flashing like i did for my deck ledger ?
Q2: can there be housewrap between it and the sheathing, since it is thin, or should the 2x6 directly be touching the sheathing, i.e. cut out an opening in the housewrap before hanging it ?
thanks
Old 03-02-2011, 06:57 PM   #2
Rewards Points: 5,336
What sort of siding is on the shed?
Ron
Old 03-03-2011, 12:35 AM   #3
there will be (so not yet) tapered cedar siding, 5x8 (on the thick side) by 8" wide
Old 03-03-2011, 08:18 AM   #4
I'd just bolt the ledger to the wall with spacers behind it to allow for air circulation.
Ron
Old 03-03-2011, 11:02 AM   #5
Question
Ron
how about the exposed sheathing behind the ledger and the spacers ?
Old 03-03-2011, 11:09 AM   #6
There is no exposed sheathing. You completely side the wall and then install the ledger.
Ron
Old 03-03-2011, 11:35 AM   #7
Not so new
12penny's Avatar
Rewards Points: 520
....go here. Page 11, figure 14.
http://www.awc.org/publications/DCA/DCA6/DCA6-09.pdf
Nevermind...didnt read far enough. This isnt a deck ledger.
12penny is offline   Reply With Quote
Old 03-03-2011, 01:37 PM   #8
Rewards Points: 24
Amakarevic, another thing that you might consider, rather than hanging your kayaks on the actual side of the shed, is to set a couple of treated posts along side of it, each with one, or two, or however many you would need, treated 2x4 or 2x6 cross pieces, so that you could still keep them close to the shed, but without having to worry about them damaging your cedar siding.
The Following User Says Thank You to DexterII For This Useful Post:
amakarevic (03-03-2011)
Old 03-03-2011, 02:42 PM   #9
Smile
i'm doing that on the other side but on this side, i do need a ledger for hanging various things. the space is tight. i have a lot of boats ...
Old 03-03-2011, 04:11 PM   #10
Rewards Points: 83
Attach the brackets through the siding into the studs? Seal around fasteners?
rubberhead is offline   Reply With Quote
Old 03-03-2011, 05:16 PM   #11
You can install blocking on the sheds interior, so you don't have to worry about hitting the studs. The hardware should be exterior rated and sealing it can't hurt.
Ron
Tags
flashing , house wrap , ledger
Wood Shed Construction- Town wants concrete pad? TJ_in_IL Building & Construction 20 07-26-2011 10:21 PM
awg size for 60' underground line from house to shed for 60 amp capslock Electrical 5 06-09-2010 11:31 AM
Connecting Ledger Board to Vertical Stud Alzipski Building & Construction 3 11-04-2009 03:53 PM
Shed Power Plan zpm Electrical 5 05-19-2009 04:33 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 12:09 PM
