Protecting A Sill Plate - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-08-2013, 03:13 PM   #1
Protecting a Sill Plate
Bottom row of cedar siding on one side of my house is only 1 inch above the soil - a 10 foot section of it is actually under gravel and soil. Pulled some siding off to repair dry rot and realized particle board and sill plate are only inches above grade. Aside from totally regrading, what are my best options? I have considered flashing, rubberized ice shield, digging soil/gravel away, replacing bottom row of siding with cement board. . . there are gutters and I keep them clean. Any ideas/suggestions would be appreciated.
Protecting a Sill Plate-100_4530.jpg   Protecting a Sill Plate-100_4528.jpg   Protecting a Sill Plate-100_4529.jpg
mnelson is offline   Reply With Quote
Old 05-08-2013, 03:21 PM   #2
Rewards Points: 13,274
#1 Please go back and add your location to your profile, just got to Quick links to edit.
#2 Go back and post some pictures. No one here can see what your seeing.
# It's code that any sheathing and or siding must be 6" above grade, guess you see why now.
With some pictures we can make some suggestions on how to make the best of what you have.
Bet it's OSB not partical board, a big differance.
mnelson (05-09-2013)
Repair/replace sill plate and joist ends heybales Building & Construction 5 02-16-2013 11:33 PM
Jacking Exterior Wall / Replacing Sill Plate Pittsville Building & Construction 2 06-16-2012 10:11 AM
Replace Sill Plate to Basement Block Wall - No anchor bolts DoItMyselfToo Building & Construction 4 09-10-2011 04:07 PM
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 09:08 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
