Protecting Cables And Pipes In Steel Studs - Building & Construction - Page 4 - DIY Chatroom Home Improvement Forum
Old 11-24-2013, 11:56 AM   #46
Rewards Points: 4,780
I'll get a picture of exposed studs if I can, but so far no luck....
jeffnc is offline   Reply With Quote
Old 11-24-2013, 11:58 AM   #47
An old Tradesmen
Rewards Points: 6,088
Merged threads.
Old 11-24-2013, 03:06 PM   #48
Plumber
TheEplumber's Avatar
Rewards Points: 348
Jeff- Basically, anyone running their cables, pipes or gas lines through a stud or plate will nail plate it as required or they won't pass inspection. And it will be 18 ga. for plumbers and whatever the electricians here have referenced.
codes are bare minimum so assume the worst. I'm not sure why you're screwing trim anyways. I've always seen it glued and nailed.
Are you a contractor doing this work for someone? Perhaps asking over at http://www.contractortalk.com/ will help too.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
kwikfishron (11-24-2013), Philly Master (11-24-2013)
Old 11-24-2013, 04:01 PM   #49
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Originally Posted by stickboy1375 View Post
OR you get factory prepunched metal studs, and just install bushings. I'd love to see a picture of the OP's scenario.
except for the tops plates ...LOL
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 11-24-2013, 04:02 PM   #50
Rewards Points: 516
wait a minute i just realized that we are now in the Building section LOL never been here before where is the EXIT ...
Old 11-24-2013, 04:30 PM   #51
chitownken's Avatar
Rewards Points: 510
Watch yourself. Someone will replace your meter with a nail gun!!
chitownken is offline   Reply With Quote
The Following User Says Thank You to chitownken For This Useful Post:
Old 11-24-2013, 06:04 PM   #52
I think we've all worked on things that shouldn't have passed inspection, yet there they are.
Gluing and butterfly nailing might work, but this is a picture rail. Screwing would be pretty standard for strength, I think. They do make those screws specifically for trim into steel studs, after all.
Old 11-24-2013, 07:08 PM   #53
Plumber
Rewards Points: 348
If it helps any- most plumbing pipes are in the lower half of the wall. Usually, only vertical pipes will be in upper part, and between studs
