Protect Asphalt Drive Fr: Hvy Trucks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-22-2011, 08:01 PM   #1
Rewards Points: 83
protect asphalt drive fr: hvy trucks
Hi,
I need about 20 tons/15 yards of pea gravel delivered for underneath a playset.
I'm not allowed to dump this in the street, according to the town (do it on a saturday?? :-)
So I will need the dump truck to dump on my asphalt driveway with an admittingly questionable base...barely to code if that.
So I am shopping around for a smaller dump truck than the 12 ton, 6 wheel truck the gravel company has. I may use a "1.5 ton" dump truck, but this company says it will take 5 trips...how does that work??
I have no idea what different trucks are like and weigh, etc....novice here.
Also, even with this smaller truck, would 2-3 layers of 3/4" plywood help spread the weight out under the wheels?
Thanks!
D270 is offline   Reply With Quote
Old 06-22-2011, 08:21 PM   #2
concretemasonry's Avatar
Rewards Points: 2,652
Since you have an asphalt driveway, you are definitely on "thin ice". The reason being is that asphalt pavement is not strong, but it strong enough to spread the load to base under it. More thickness hepls somewhat. If the base is not good or compacted well enough or is moist the strngth goes down. This is in contrast to a rgid pavement, like concrete that spreads the load out to a much larger area (sort of similar to a lot of sheets of 3/4" plywood).
As far as I know there is no "code" about the pavement thickness, the base thickness and compaction or the subgrade quality. There are some non-binding "acceptible standards" or just installation guidelines.
Call the aggregate supplier and they can give you suggestion since they run into this frequently.
Dick
concretemasonry is online now   Reply With Quote
Old 06-22-2011, 11:36 PM   #3
or you could use something like this instead of the pea gravel.
http://www.rubberecycle.com/playground_rubber_mulch.asp
1910NE is offline   Reply With Quote
Old 06-23-2011, 12:24 AM   #4
liscenced electrician
Rewards Points: 538
I would either get smaller loads or just dump it in the street and clean it up as quick as you can.12 yards will more than likely cause noticeable damage
jimmy21 is offline   Reply With Quote
Old 06-23-2011, 05:38 AM   #5
Rewards Points: 4,800
isn't dick's new car pretty nice ? ? ? i'd dump it in the street OR on the driveway's apron then rent a bobcat to trundle it up to your site,,, any pavement ' code ' would be normally be a developer's issue w/his subs altho, on occasion, local govt officials do spec driveways, too.
Old 06-24-2011, 01:03 PM   #6
Rewards Points: 83
Thanks!
re: replace asphalt driveway. best method?? gramps416 Building & Construction 12 05-24-2011 11:50 AM
Need advice on 1 1/2 inch of asphalt overlay on concret and old Asphalt stanlam Landscaping & Lawn Care 1 11-28-2010 04:50 PM
Satellite Rx external hard drive. Wildie PC Repairs & Upgrades 4 09-13-2009 11:06 PM
Moving C drive files Thurman PC Repairs & Upgrades 14 08-17-2009 03:13 PM
Hard drive redline PC Repairs & Upgrades 14 03-06-2009 04:27 PM
