Old 07-23-2009, 07:31 PM   #1
Default Pros vs cons for finished garages
The house I just bought has drywall hung in the garage as well as first first coat of mud and tape applied. I'm trying to decide whether I should go the extra mile and finish it with another couple coats of mud and paint.
What are the pros and cons of leaving it rough vs. smoothing it out and painting it???
Keep in mind, I spend a lot of time in the garage working on my hotrod project.
mopowers is offline   Reply With Quote
Old 07-24-2009, 12:24 AM   #2
I think it would be worth finishing. As long as the first coat is Ok it should be fairly easy to add 2 more coats. Should also not be too costly to just pay a pro to do it. They will be done in 2 days and there will lilely be far less dust. The unfinished walls can never be washed. Since they are white you will likely get them very dirty working on cars. A nice coat of quality paint will clean up any time you want. Plus the resale value will be a bit higher or at least it will be easier to seel if you ever do.
Do it. You will be glad you finished it off.
beerdog is offline   Reply With Quote
Old 07-24-2009, 02:24 AM   #3
Yes, I would recommend to finish it. But first ensure you have all the electric, HVAC, etc. installed that you want.
More On This Topic
Alright, this is a really great example of a different kind of texture. We started with that really light texture that we had in the other room, but we added some more mud to this- some plaster on the wall with a trowel to get this look that we wanted... Read More »
In this clip we're going to take a quick look at some of the various clear coat finishes that you can put on your stained wood piece. Some of the different finishes you can use are Shellac, this one happens to have an amber hue to it. Just a clear... Read More »
Hi, I'm Greg B. from Expert Village. Today we're going to talk about model cars. What you might want to do is look your car over carefully. See if you have any bleed through and if you do you could add some more primer on there. What your primer does is... Read More »
Hi! My name is Scott Reil and on behalf of expertvillage.com I will like to talk to you about vegetable gardening. One of those chores that comes up in every garden is weeding. Weeds happen. Weeds don't necessarily mean that you are doing anything wrong... Read More »
Knowing the properties and uses of paints will save a great deal of time, money and work over time. The right paint choice will help the finish last its longest and look its best. Read More »
Trex decking LL1 General Discussion 48 10-12-2009 02:56 PM
rewiring garage, questions about conduit pros and cons schmolze Electrical 32 05-08-2009 03:59 AM
purple martin/bat house pros and cons? DangerMouse Pest Control 12 01-15-2009 09:25 AM
Please explain the pros and cons to gutters. curls00 Roofing 1 11-14-2007 02:42 PM
Basement flooring choices Brik Building & Construction 23 01-27-2007 04:38 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
