Properly Covering Up Window From Outside. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 01:13 AM   #1
properly covering up window from outside.
because of a new layout, i need to cover up a window. I already taken it out, framed the window for a piece of plywood and nailed the plywood. Now how would i water proof this before putting up new siding?
jclee is offline   Reply With Quote
Old 02-27-2013, 06:31 AM   #2
Rewards Points: 150
Gotta get tar paper(tyvek) under what's behind your top post piece of siding if u can get behind it good u might have to slice it go get behind Dab a little bit of caulk in the top two corners of where old paper meets new paper, for the bottom just over lap the paper that was there. Start from bottom
kaschmid3 is offline   Reply With Quote
Old 02-27-2013, 06:31 AM   #3
Rewards Points: 150
And always overlap top piece over bottom piece
window unit ac not cooling properly in mobile home p5200 HVAC 9 07-05-2012 01:52 PM
Basement window finishing Dmoraski Windows and Doors 3 05-29-2012 04:08 PM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 10:30 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
