Old 09-14-2012, 05:45 PM   #1
Proper way to install rake trim boards on long roof peak?
Thank you all!
jubee is offline   Reply With Quote
Old 09-14-2012, 07:13 PM   #2
how many small pieces are there. there should only be 2 pieces total on any run. why did you change it. i didn't see anything wrong with the before picture. have you already paid them?
Old 09-14-2012, 07:28 PM   #3
Pic 2: what a mess! Pros may say it's just cosmetic and not that noticeable from the ground but to me it says the work was done by chimps.
retired guy 60 is offline   Reply With Quote
Old 09-14-2012, 07:31 PM   #4
GBrackins's Avatar
and not very well trained chimps ....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is online now   Reply With Quote
Old 09-14-2012, 07:51 PM   #5
That's shingle moulding not a rake board.
The board under it is a rake board not a rack board.
It does look like poop though.
I would have replaced it with vinyl rake moulding so it would never rot again.
It only needed 2, finish nails not 1/2 dozen staples.
It's also not line up with the other piece.
Also the gutter was run to long.
Old 09-14-2012, 11:30 PM   #6
For me if I have let's say 16'8" and only 16' material, I cut it back to 14' and do a 2'-8" piece.
mae-ling is offline   Reply With Quote
Old 09-15-2012, 12:56 AM   #7
Maryland
Nice hand print on the rake in photo #1... Would drive me nuts...
Pittsville is offline   Reply With Quote
Old 09-15-2012, 02:10 AM   #8
Although the work is kind of a mess it is definitely fixable. The real issue is whether you want to risk having the original contractor take a third crack at this. If it weren't so high up it would be an easy fix for someone with decent do it yourself skills. The comments made by others clearly explain what needs to be done. Good luck.
Old 09-15-2012, 06:21 AM   #9
It's the second highest quote among the 4 we got.
Old 09-15-2012, 06:22 AM   #10
They haven't painted it yet. First part of the job is to repair the rotten wood. Second part is to paint.
Old 09-15-2012, 06:23 AM   #11
Thank you. I had to google what rake board is.
Old 09-15-2012, 08:01 AM   #12
Household Handyman
I do this type of work, and re-work (as in this case), and it just makes me cringe/cuss when I see this type of work done. Doesn't anyone have any idea of craftsmanship any more?
Old 09-15-2012, 04:01 PM   #13
Quality craftmanship is hard to find nowadays...
To make you feel better, you just have to wait until the paint job is done... This looks like something that is "almost done".
How much communication do you have with your hired professionals?
oodssoo is offline   Reply With Quote
Why can't I find a good thatch rake or pine needle rake? carl1864 Landscaping & Lawn Care 5 06-05-2011 02:01 PM
Need opinion on this roof profenx Roofing 14 10-12-2010 01:56 AM
Install a deck on top of a EPDM flat roof. -Pjackso Roofing 16 08-02-2010 04:35 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Modified bitumen vs 60 mil EPDM membrane Flat Roof doingygirl Roofing 11 01-07-2008 09:41 AM
