-   -   Proper way to install rake trim boards on long roof peak? (http://www.diychatroom.com/f19/proper-way-install-rake-trim-boards-long-roof-peak-156821/)
jubee 09-14-2012 04:45 PM
Thank you all!
DannyT 09-14-2012 06:13 PM
how many small pieces are there. there should only be 2 pieces total on any run. why did you change it. i didn't see anything wrong with the before picture. have you already paid them?
retired guy 60 09-14-2012 06:28 PM
Pic 2: what a mess! Pros may say it's just cosmetic and not that noticeable from the ground but to me it says the work was done by chimps.
GBrackins 09-14-2012 06:31 PM
and not very well trained chimps ....
joecaption 09-14-2012 06:51 PM
That's shingle moulding not a rake board.
The board under it is a rake board not a rack board.
It does look like poop though.
I would have replaced it with vinyl rake moulding so it would never rot again.
It only needed 2, finish nails not 1/2 dozen staples.
It's also not line up with the other piece.
Also the gutter was run to long.
mae-ling 09-14-2012 10:30 PM
For me if I have let's say 16'8" and only 16' material, I cut it back to 14' and do a 2'-8" piece.
Pittsville 09-14-2012 11:56 PM
Nice hand print on the rake in photo #1... Would drive me nuts...
retired guy 60 09-15-2012 01:10 AM
Although the work is kind of a mess it is definitely fixable. The real issue is whether you want to risk having the original contractor take a third crack at this. If it weren't so high up it would be an easy fix for someone with decent do it yourself skills. The comments made by others clearly explain what needs to be done. Good luck.
jubee 09-15-2012 05:21 AM
It's the second highest quote among the 4 we got.
jubee 09-15-2012 05:22 AM
They haven't painted it yet. First part of the job is to repair the rotten wood. Second part is to paint.
jubee 09-15-2012 05:23 AM
Thank you. I had to google what rake board is.
Thurman 09-15-2012 07:01 AM
I do this type of work, and re-work (as in this case), and it just makes me cringe/cuss when I see this type of work done. Doesn't anyone have any idea of craftsmanship any more?
oodssoo 09-15-2012 03:01 PM
Quality craftmanship is hard to find nowadays... :(
To make you feel better, you just have to wait until the paint job is done... This looks like something that is "almost done".
How much communication do you have with your hired professionals?
