Proper Way To Attach Travertine To Brick... - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 04:53 PM   #16
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Can I just mix some of the same modified white thin-set to fill in a couple of small joints as grout
You could, I can't say I've never done it myself.
The problem will be the thinset will be much more sticky than grout would be and therefore harder to clean up. You will constantly be dragging the thinset out of the joint. Also thinset is likely to sag and not stay in a vertical joint. Just depends on how wide of a joint you are talking about.
XXX
Old 12-08-2010, 07:56 PM   #17
That looks awesome! Good job!
Nucon is offline   Reply With Quote
Tags
fireplace , lath , stone , travertine
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Attach Bike Rack to Double Wythe Brick Wall stubits Building & Construction 13 05-13-2010 10:32 AM
Potential foundation issues oklahomaguy32 General DIY Discussions 7 02-14-2010 03:12 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 03:04 PM
