Proper Support - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 05:58 PM   #1
Rewards Points: 150
Proper support
Hi guys,
I would like to install a window in an exterior wall of a ranch home. The wall that I want to put the window in is parallel to the ceiling joists. When I remove some of the existing studs in the exterior load bearing wall I don't want to cause any damage to the structure of my home. How would I properly support the structure before I do this? I know what to do if the ceiling joists were perpendicular to the wall and I understand how building a temporary wall or support to place under the perpendicular ceiling joists would support the structure so that I could remove studs from the exterior load bearing wall, but if the ceiling joists are parallel to the wall and I build a similar support and install it the same way as you would for perpendicular joists how are you then supporting the load on the exterior wall when the joists are not sitting on the wall (i.e. running parallel to the wall)????
Any help would be greatly appreciated!
Thanks!
Steelhead is offline   Reply With Quote
Old 02-05-2012, 06:16 PM   #2
Retired carpenter
Put some upright 2x4s on the outside holding up the rafter tails or the fascia board.
abracaboom is offline   Reply With Quote
The Following User Says Thank You to abracaboom For This Useful Post:
Steelhead (02-05-2012)
Old 02-05-2012, 06:44 PM   #3
Rewards Points: 150
Abracaboom,
I said thank you without really thinking about what you said. This wall is under the gable end of the house so there are no rafter tails to put any supports under. The fascia board is pretty far up. Do I really want to support the wall with 2 x 4s under an angled fascia board?
Old 02-05-2012, 07:05 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,006
if the wall is supporting only the gable end it wont be to big a deal as there isnt very much weight on it.. as long as you open things up and reframe quickly you will be fine provided there isnt another floor above
woodworkbykirk is offline   Reply With Quote
Old 02-05-2012, 07:13 PM   #5
Rewards Points: 12,868
How big a window are you putting in?
A few pictures would sure be helpfull.
What's on the outside for siding?
If it's just a window 3' or less wide then you would not need a support wall in most cases.
Old 02-05-2012, 07:33 PM   #6
Rewards Points: 150
That's what I was hoping you would say. There is no second floor. Thanks!
Old 02-05-2012, 07:38 PM   #7
Rewards Points: 150
I'm in the planning stages right now. I don't think the window will be more than three feet wide anyway. Thanks
Old 02-05-2012, 07:41 PM   #8
Is there other windows on that same side of the house. I try to frame a new window so they all match in height, unless it's a bathroom winodw.
Old 02-05-2012, 07:55 PM   #9
Rewards Points: 150
There are no other windows, this will be the first on this side of the house.
Old 02-05-2012, 08:12 PM   #10
Civil Engineer
Rewards Points: 4,522
I had a similar issue when I installed a 6 foot French door on an outside bearing wall where the joists run parallel to the wall. I was in luck, there was a double top plate, so I was able to open up the wall, and remove the studs, without any need for support of the double top plate. Of course I had to install a header, and you do too, but I worked fairly quickly, and installed a steel beam on doubled jack studs tight against the double top plate. The tolerance was so tight I had to hammer the steel beam into position using a sledge hammer. Worked very nicely.
You need to VERY CAREFULLY evaluate the loads on your window, and determine if the existing framing is going to hold up temporarily while you install the header (yes, you are going to need a header). If there is limited load, and it sounds like there might be, you may not need any temporary support, as has been suggested by other. If you have only a single top plate, or you plan to remove the top plate, that requires careful attention to detail. If the existing framing is inadequate, there are various techniques for providing temporary support by installing a temporary beam in the attic above.
Old 02-05-2012, 09:59 PM   #11
Rewards Points: 150
Thanks Daniel for all your help. I'll take all these suggestions into consideration.
Old 02-05-2012, 11:22 PM   #12
Retired carpenter
Originally Posted by Steelhead View Post
Abracaboom,
Duh. You can take away your thank you if you want.
Ranch house, three foot opening . . . no support needed (under normal circumstances).
Main structural support beam HELP!!! Daniel048225 Building & Construction 34 02-17-2011 12:35 AM
Alterative ways to support main beam frizbplaya Building & Construction 8 01-29-2011 12:10 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
proper support for floor joists in my "man cave" mike d Building & Construction 14 04-25-2010 11:06 PM
Temporarily remove basement support post ColinD Building & Construction 14 12-04-2008 06:07 PM
