Proper Load. Bearing Header - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-15-2012, 11:34 AM   #1
Proper load. Bearing header
Hi I have a room 20 x 10 with 9' ceiling. It use to be 2 10 x10 rooms with a bearing wall in the center now it has 2 6x6 beams spanning the 10' length I want to remove the 6x6 beams and bury a header so I need help in determining what size header to use. The rafters run the 20' this is a one story house with attic space and the room is located in the right hand corner of house
Wfd1712 is offline   Reply With Quote
Old 07-15-2012, 12:02 PM   #2
Rewards Points: 13,270
You need someone on site to look this over, no way someone 1000's of miles away should be even guessing on this one.
mae-ling (07-15-2012)
Old 07-15-2012, 12:13 PM   #3
Rewards Points: 2,210
Please don't take any advice from us here.
Sorry.
You need a structural engineer to come look at it.
mae-ling is offline   Reply With Quote
load bearing wall removal ronnteresa Building & Construction 11 03-03-2012 01:39 AM
Removing part of a load bearing wall - what size header Mike Sch Building & Construction 1 01-09-2011 11:14 AM
Load bearing wall! Newtsjetson Building & Construction 2 12-19-2010 08:46 AM
Non load bearing wall door header? nocarpenter Building & Construction 10 06-11-2009 05:16 PM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 05:25 PM
