Problems With Laser Levels - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-15-2009, 05:08 PM   #16
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I do have a low cost Laser Square that has self release dogs to release it from being fastened to the wall with adhesive putty. I've only use this Level the floor to lay out 90 partitions.
The Stanley S2-XL is three times as expensive as the S2 but then the S2-XL is claimed to have a four times brighter beam and much greater bubble level accuracy.
Specs on the S2:
http://www.stanleytools.com/default....r+Level+Square
Specs on the S2-XL:
http://www.stanleytools.com/default....3153+Laser+Lev
The good thing about this class of Lasers is that they project a 'Chalk Line'
as compared to the Lasers that project a dot, like a pointer. A Dot type laser is better over greater distances but usually require an extra step in pulling a horizontal line.
http://www.lascolaser.com/show_produ...-Line%20Lasers
Problems with laser levels-stanley-s2-laser1a.jpg   Problems with laser levels-stanley-s2-xl-laser-level.jpg   Problems with laser levels-stanley-s2-laser2a.jpg   Problems with laser levels-stanley-s2-laser3a.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-06-2009, 02:46 PM   #17
Product Design student
Plastic Brick's Avatar
Alright; here are some last minute sketches. These are redesigns of the StraightLine 120. After this I have to make the designs final. I would appreciate any feedback. Thanks
Plastic Brick
Problems with laser levels-010.jpg   Problems with laser levels-011.jpg   Problems with laser levels-012.jpg   Problems with laser levels-013.jpg
Plastic Brick is offline   Reply With Quote
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 02:04 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
Laser Levels laserlady Carpentry 10 12-14-2006 01:40 PM
