Old 06-26-2011, 09:17 PM   #1
Problems with deck rail installation
I am installing a Timbertech Radiance Rail system. It is great and generally easy to work with. I really like the fact that all drill holes are the same size as are all the screw heads. I am not a carpenter, just a homeowner with basic skills.
Today, I had to put together a section of the rail that is on a 45 degree angle. Not wanting to mess up the product, I did a mock up with a 2x2. After a lot of trial and error, I finally got the length right. Her is my question -- when I installed the rail, the angle was not quite right and there is gap on the ouside part of the rail. the portion on the front is flush, but it looks like the angle was slightly off. I can't tell if it is because the posts are slightly twisted. Any thoughts? Caulk will cover it, so it is not a huge, deal, I am just trying to learn how to do it better as there are 3 more sctions with the angle.
Also, is there a good trick for measuring the length on the 45 angle?
Thanks.
Ranger1227 is offline   Reply With Quote
Old 06-26-2011, 11:02 PM   #2
I'm thinking the corner angle was not 90 degrees, more like 89 or so. As a result, the cut of 45 was off.
Use scrap wood the same width as the railing. Cut the test angle on that and test fit it. When it sits correctly, cut the rail.
It has nothing to do with the, " length on the 45 angle".
You get the angle correct, the cuts are the same length.
Ron
B. Franklin 1759
Deck Addition - Floating to Attached Foundation eemichael83 Project Showcase 15 08-22-2010 10:40 PM
A couple of Deck railing and privacy fence/screen question EightmanVT Building & Construction 9 06-01-2010 09:03 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
