Problem With Slope On Garage Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 10:15 AM   #1
Problem with slope on Garage Floor
Built my home 5 years ago and the garage floor was poorly done. Has some uneven spots that pools water off of wet vehicles and it slowly drains toward the house instead of out the garage door. Keeps things a little mildewy near the wall. What is a good solition?
skidboot77 is offline   Reply With Quote
Old 01-24-2010, 12:23 PM   #2
jlhaslip's Avatar
Rewards Points: 920
One option is to pour a 2 inch top coat, but that is expensive.
Another option would be to use a grinder with a diamond blade to cut drainage lines into the slab. Wear a dust mask.
jlhaslip is online now   Reply With Quote
Old 01-24-2010, 01:01 PM   #3
Household Handyman
Rewards Points: 1,408
On top of the problem with the slope, you are in a high humidity state-Alabama. I'm next door. One thing I would try before spending big monies for a build-up (the 2") or having drainage slits cut in: Do you have or can borrow a de-humidifier? Place a de-humidifier in the garage and let it run. Most of the better de-humidifiers come with a way to attach a garden hose for drainage so that you don't have to remember to drain the tank all the time. This will only work if you have a way to run the garden hose out of the garage and away from the house. Placing the unit on something a foot or two from floor level will help with the drainage also. I have a de-humidifier I use in my home during the summer months due to humidity here. I made a way to attach a 3/8" drain tube which is connected to a line through the floor, under the house, and into the main waste drain. Just one thought, David
Electrical problem in garage ginaca Electrical 10 04-19-2009 07:51 PM
Shower floor slope Not Sure Building & Construction 11 06-10-2008 12:12 PM
Bathroom 'wet floor' - floor slope options Couch Plumbing 9 03-11-2008 05:42 PM
