Problem With Kitchen Cabinets - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 06:52 PM   #1
Problem with kitchen cabinets
Hi ,
I have a new house with a problem with the kitchen cabinets. Please see the attached picture. The contractor says that nothing can be done but I was hoping to get some ideas here. The only thing I can think of is to try to make it a little bit smother with some joint compound. I am guessing that it will never look right but it would be nice if it looked better.
Thanks in advance
Gary
GandGTarr is offline   Reply With Quote
Old 07-22-2012, 07:22 PM   #2
Rewards Points: 3,718
Originally Posted by GandGTarr View Post
Hi ,
Thanks in advance
Gary
When you say contractor,do you mean the home builder??.
Canarywood1 is offline   Reply With Quote
Old 07-22-2012, 07:28 PM   #3
Yes, it is the home builder. The builder sent out the person who installed the cabinets but the cabinet installer said that it was a problem with the wall not being square and he could not do anything.
Old 07-22-2012, 07:40 PM   #4
You have a years warranty on your home,call the builder and tell him to fix it,it's his problem not your's,and don't let him tell you any different.
The Following User Says Thank You to Canarywood1 For This Useful Post:
GandGTarr (07-22-2012)
Old 07-22-2012, 07:44 PM   #5
DIY staff
Rewards Points: 7,174
Post a picture from further back,please.
Old 07-22-2012, 08:31 PM   #6
Here is the picture you ask for.
Old 07-22-2012, 08:49 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 504
If he had installed a small bull nose that extended a little out past the edge of the furrdown it would have hidden all the imperfections.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (07-23-2012)
Old 07-23-2012, 07:24 AM   #8
AHH, SPANS!!!
Rewards Points: 1,166
yuck! the cabinet guy should add a tapered shim behind the trim that allows the trim to extend out flush to the corner of the drywall. I'm sure he has some of the wood stock from the cabinets to do so. The only time you would see the tapered piece is when the cabinet door is open and you probably will not even notice it if done correctly. tell him to pull the cove and add a shim!
hand drive is offline   Reply With Quote
Old 07-23-2012, 10:42 AM   #9
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
It's not your problem. That soffet should be at least 13" deep.
The cabinet installer is not to blame.
If the GC refuses to fix it. Send him a certified letter quoting as much of your agreement as possible. Give him 30 days to rectify it or you will get it done by the most "expensive licensed contractor" you can find and send him the bill.
I love litigation
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Old 07-23-2012, 11:40 AM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 504
Looking at that a little closer I see there is a corner bead there to the right of that cabinet, my guess is that the extra thickness is sheet rock mud floated out to the corner bead. I do agree that the furrdown should have been out 13 inches.
Jim
Old 07-23-2012, 01:22 PM   #11
Thanks for all your advice so far.
By the way, I think that jiju1943 is right that the joint compound was just floated out to make the wall even. Then later the joint compound cracked and crumbled due to house movement finally resulting in the defect above the cabinet.
If I can't get the contractor to do something ( I am going to try again), could I just rebuild the edge above the cabinet by using a little joint tape for reinforcement and then covering it with joint compound? I am no pro but I have taped joints before so I have a little experience.
Gary
Cabinets To Go! CapnHawk Kitchen & Bath Remodeling 64 03-29-2017 02:14 PM
Leveling Kitchen Cabinets for Granite - how level?? vsheetz Kitchen & Bath Remodeling 13 03-02-2012 07:54 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Kitchen Cabinet installation, upper cabinets not level BillyJack Kitchen & Bath Remodeling 0 06-30-2010 08:07 AM
Installing Cabinets In Un-level Kitchen whiskeykid Carpentry 14 01-31-2009 07:43 AM
