Old 05-08-2007, 09:22 PM   #31
problem contractor-help please
Did you by any chance always go with the lowest bidder?.....
send_it_all is offline   Reply With Quote
Old 05-08-2007, 09:25 PM   #32
These situations are what a contractor's bond is for. You should be able to contact the bonding company and get some sort of satisfaction. They will in turn go after the contractor for the money.....he was bonded, right?
Old 05-08-2007, 09:27 PM   #33
I don't care what anybody says if the contractor asks for any money before the material is delivered or any work is done he's up to no good.
krpen71 is offline   Reply With Quote
Old 05-08-2007, 10:43 PM   #34
Longtooth's Avatar
first you'll need a judgment from a court of law.
Longtooth is offline   Reply With Quote
Old 05-09-2007, 08:27 AM   #35
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
He would also need to be actually 'bonded'. Not every state requires that. The states we work in do not.
- Build Well -
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 09:08 PM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 08:24 AM
