Problem With Chain Link Fence Gate.... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-03-2010, 09:50 AM   #1
long island, NY
problem with chain link fence gate....
hi
We have an old chain link fence. Overall, it's in very good shape. However, the 2 posts that flank our main gate have sort of migrated over time. They're further apart than when they were initially installed.
I think one post got a bit of a beating over the years. It's close to the driveway, and was tapped by a few trucks and snow plows. It was straightened out again, but I think it shifted? At any rate, it's reasonably plumb, but moved about an inch.
Now the latch won't catch. It WOULD catch if the posts were closer together (by 1-2"). The gate still swings well, and is reasonably straight.
What's an inexpensive way to fix this idiotic problem? Right now, our gate has one of those child-proof latches (push the rod down to flip the gate latch open). The edge of the latch misses the adjacent post by a few millimeters, although the latch is designed for it to be about 1-2" closer.
thanks for your advice
diy'er on LI is offline   Reply With Quote
Old 05-03-2010, 09:55 AM   #2
waterman1971's Avatar
Rewards Points: 150
j bolt hinge
waterman1971 is offline   Reply With Quote
Old 05-03-2010, 10:05 AM   #3
long island, NY
Originally Posted by waterman1971 View Post
j bolt hinge
What is that? Where should I put it? (Sorry, my ignorance is in full swing... as is my gate )
oh wait, is that a replacement hinge? Where could I buy that?
Last edited by diy'er on LI; 05-03-2010 at 10:06 AM. Reason: brain beginning to wake-up
Old 05-03-2010, 10:12 AM   #4
Rewards Points: 150
1 remove your current gate from the hinges
2 remove gate hinges
3 drill through the post
4 place the bolt through the hole, snug it up hand tight with one nut on each side of the post
5 place the gate on the hinge bolt
6 adjust the new hinge to fit the opening size using the two nuts.
7 tighten the nuts
8 drink beer
Old 05-03-2010, 10:41 AM   #5
long island, NY
7 tighten the nuts
8 drink beer
thanks so much.... I MAY have to do step #8 twice.... especially if I still have smuttynose old brown dog ale in the fridge
Old 05-03-2010, 10:48 AM   #6
Rewards Points: 150
After all that hard work step 8 may need to be performed more than twice.
Old 05-03-2010, 05:41 PM   #7
Rewards Points: 1,016
Another option would be to take the gate to a fencing company that builds gates and such - they can probably readily modify or make other suggestions.
Old 05-03-2010, 06:23 PM   #8
kwikfishron's Avatar
Rewards Points: 370
Remove gate, remove bent and tweaked gate post supporting gate, install new post to support gate, drink beer. Tomorrow, re-install gate, then drink more Beer.
kwikfishron is online now   Reply With Quote
Gate Design Question rocknroll99 Building & Construction 5 04-13-2010 07:46 AM
Fence gate anchor/pin ??? jjrbus Landscaping & Lawn Care 1 03-10-2010 07:05 AM
sagging gate issue Thanat0s24 Building & Construction 2 04-17-2008 01:19 PM
Chain link problem? jeremylindquist Landscaping & Lawn Care 1 06-24-2007 06:34 PM
Fence Post Problem cdubim Building & Construction 3 03-12-2007 01:09 PM
