Old 06-14-2008, 07:46 PM   #1
Problem with bricks in fireplace box pulling away from interior wall
Not sure how to describe this better. It seems that the bricks inside the wood-burning fireplace are pulling away from the interior wall. There's no mortar/grout in between some of those bricks. This house was built in the 1950s. Is this something that I should be able to tackle on my own? I guess I could apply mortar/grout, but then will that keep the bricks in place? Or should this be done by a professional---maybe a mason?
proofer is offline   Reply With Quote
Old 06-15-2008, 08:54 AM   #2
mason
Best to have a mason come in and fix it. If you do try and fix it yourself you need to use fire clay, not a standard mortar. The fire brick are supposed to be very close together. Generally there is a very small amount of fireclay separating them.
6stringmason is offline   Reply With Quote
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 09:17 AM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
temper glass for fireplace mantel shelf sil Interior Decorating 3 02-13-2008 09:10 PM
Possible to build direct-vent fireplace? DIYerself General Discussion 3 12-22-2007 11:07 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
