Preventing Water Damage In Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-24-2010, 08:37 AM   #1
Preventing Water Damage in Garage
I've got a garage that apparently the plywood walls area wicking up water. (I originally thought it was mold.)
http://img814.imageshack.us/img814/563/43416662.jpg
http://img375.imageshack.us/img375/2072/12306190.jpg
The house was built in 1980 and sits at the bottom of a hill (water isn't a huge problem in our home, but it's obviously showing some signs). Should I do anything to fix this?
I am not handy at all, but for instance, I'm wondering what the wall supports look like underneath this plywood--I doubt it's metal.
Thanks for the help!
yellowhouse is offline   Reply With Quote
Old 09-25-2010, 06:26 AM   #2
Rewards Points: 4,656
probably the 1st item would be to prevent water from coming into contact w/the walls,,, where's the wtr coming FROM ? ? ? if under the garage door, a slot drain will probably resolve that part.
' Should I do anything to fix this? ' don't know - its YOUR home,,, if it were ours, we'd be on it faster'n a hungry dog spotting a steak
Old 09-25-2010, 02:53 PM   #3
A trench to help the water go elsewhere is a good start. If snow builds up there, the wall might have to be sealed at the bottom with sealant.
Stillwerkin is offline   Reply With Quote
Tags
garage , water
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Need some advice on buying home termite & water damage. Mr Heshup General DIY Discussions 1 03-29-2009 03:06 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
