Old 02-05-2008, 05:07 PM   #1
Pressure Treated Wood-Direct Ground Contact
When the manufacturers say that pressure treated lumber can be placed in direct contact with the ground, do they REALLY mean in direct contact?
What about below grade or to build a small retaining wall? How long is it supposed to last?
Randell Tarin is offline   Reply With Quote
Old 02-05-2008, 05:28 PM   #2
You can use treated lumber for direct ground contact but just remember that nothing lasts forever. Even treated wood will rott eventually
Chops is offline   Reply With Quote
Old 02-05-2008, 05:32 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
http://wilwaylumber.com/howto/howto082.htm:
"Some estimates place the average life of pressure treated lumber at over 50 years. Some manufacturers guarantee the life for 30 years."
Also: Check the actual rating of the wood:
http://ezinearticles.com/?Building-W...les!&id=239136
- Build Well -
Old 02-05-2008, 05:37 PM   #4
That's longer than I'll live!
Thanks for the replies!
Old 02-12-2008, 09:41 PM   #5
remodeling pro
Yes, they really mean it... of course their business depends on selling you new PT wood a few years later. The life of each piece of wood will vary, depending on exactly where it came from within the tree, which has a direct effect on how well it accepts the treatment. I have seen PT wood rot in less than 2 years, and other materials that lasted more than 15.
For material that will last the longest, find a supplier that can provide you with material treated to .60 retention rate. This is the standard for marine usage, and while it will be expensive to purchase, factor in the labor cost a few years down the road to remove and replace what you built the first time, and it is much more attractive, especially for something as labor intensive as a retaining wall.
troubleseeker is offline   Reply With Quote
Old 02-12-2008, 09:54 PM   #6
remodeling pro
Yea, the same marketing people who 'gaurantee" latex caulking for 50 years, the tires on my truck for 75K miles, and the battery for 8 years.
While I have your attention Atlantic, could I interest you in buying some of my special pills? I "gaurantee" they will add 3" to your manhood.
Old 02-12-2008, 09:56 PM   #7
Hey, That's why I posted it as a quote from an industry "source". It's not my personal report. Boy, you had to do some digging to find that one....it was posted over a week ago...
- Build Well -
Old 02-12-2008, 10:20 PM   #8
Electrical Contractor
That the best you can do???
I get emails daily offering up to 6"
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 02-13-2008, 06:44 PM   #9
your totaly right!! good post!! keep posting!! like that!!
Bulldog UK - Sheet Metal supplier
Last edited by AtlanticWBConst.; 02-13-2008 at 06:50 PM. Reason: Advertising Link Removed
katherine23 is offline   Reply With Quote
Old 02-13-2008, 10:20 PM   #10
remodeling pro
Very observant Atlantic, but I had a legitamate excuse. Actually went out of town for a week with just my wife . Guess I found other things to distract me at night.
Old 02-13-2008, 10:25 PM   #11
remodeling pro
Sorry, but if I had access to the "good" six inch stuff, I would not have to be a contractor and deal with so many morons all day long; I'd save it all for myself and be "in the movies".
Old 10-14-2011, 09:35 AM   #12
Pressure treated lumber has different ratings. some are .25, some .50 and some as high as .60. These numbers refer to the amount of chemicals per foot of board in lbs. If you are putting a board in direct contact with soil it's best to use the highest number available in your area to get the longest life from the wood.
If you are using the lumber for a post (ie deck support or fence post) it is best to seal the lumber with tar to help prevent as much water from entering as possible.
Remember that the wood is pressure treated mainly to keep insects out and does not make the lumber water proof. You'll still have to "treat" your lumber often, with some form of water sealer, ie Thompson's. Be sure to cover as much as possible, especially the cut sections of wood.
With the right care your lumber should last longer than you, but not forever.
yeag6154 is offline   Reply With Quote
Old 10-14-2011, 03:16 PM   #13
dpach's Avatar
Where I live you can buy different "grades" of pressure treated wood. For direct contact or buried in ground, they recommend what is called "PWF" grade (Preserved Wood Foundation). This has the best rating for ground contact and has the longest life expectancy. It is used for below grade applications like wood basements, footings, etc.
Here, the PWF lumber is CCA treated, not ACQ since you don't have to worry about human contact like you would on decking, etc. But different suppliers may use ACQ also.
dpach is offline   Reply With Quote
Old 10-14-2011, 09:59 PM   #14
JOATMON
ddawg16's Avatar
Come on, everyone knows that when it comes to woodies, I mean wood, 6" is actually 5 1/2"
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 10-14-2011, 10:52 PM   #15
liscenced electrician
has pressure treated lumber improved over the years? My fence posts are sure rotten
jimmy21 is offline   Reply With Quote
how long to let pressure treated wood dry before painting? vendejp Painting 18 08-08-2012 09:53 PM
Pressure treated wood - attracts bees? mcvane Carpentry 4 08-31-2007 09:43 AM
Painting pressure treated wood Crackers Building & Construction 1 08-27-2007 11:51 AM
Wood & Ground Contact Medium_Pimpin' Building & Construction 2 07-15-2007 11:28 AM
use of pressure treated wood in the garden bscout Landscaping & Lawn Care 7 06-07-2007 12:23 AM
