Pressure Treated Wood Dimensions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-29-2011, 11:56 AM   #1
Adding new room construction. Haven't been to lumber yard yet to measure.
PT sills on cinderblock foundation wall. Are the treated 2"x8" actually 1 5/8" high or standard 1 1/2" ?
Is their a chart for actual current lumber dimensions available on the web ?
stymie222 is offline   Reply With Quote
Old 04-29-2011, 05:49 PM   #2
Civil Engineer
Rewards Points: 4,520
There are "standard" charts, however I have noticed that a modern 2x8 may be either 1-1/2 inches or 1-5/8 inches, depending on the manufacturer. The width sometimes varies a little also. Best to actually measure your beam to be sure.
Old 04-29-2011, 08:47 PM   #3
Registered User
Rewards Points: 4,912
Most the pressure treated here are 1-5/8 and 1/8" wider because of the treatment when green. You can get kiln-dried-before-treatment which are 1-1/2 after treatment, for more money. Check your plans if a one story room addition on block, you can probably use 2x6 on the 6" block for 2x6 walls, 2x4 plate for 2x4 walls, whichever has been approved on the engineered/stamped plans. http://publicecodes.citation.com/ico...006_par003.htm
Or are you two-story with the 8” block?
Gary
Old 04-29-2011, 08:54 PM   #4
kwikfishron's Avatar
Rewards Points: 86
The 1/8” your concerned about doesn’t even exist in the eyes of a framer.
kwikfishron is online now   Reply With Quote
Old 04-29-2011, 09:32 PM   #5
Framing Contractor
It does for me. If your doing a foundation for an addition and you have to have the top of the new floor joists even with the top of the existing floor joists, the top of the foundation has to be figured out exact. If you use double sill plate and it's 1/8" difference, that's a 1/4" that the new joists would be sitting above the top of the existing joists. you even have to figure in the thickness of the sill seal.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 04-29-2011, 09:35 PM   #6
Registered User
Though he is matching up the floor elevations of new/old. It is a big deal there...... The biggest problem when matching is the existing floor sags in the middle-- follow that slope with the new if only 8' or install level..... but you are correct... a remodel carpenter would/should watch for that, most framers wouldn't- unless adding joist, stud, plates for wall sheathing break point when specified. Or a rake wall tying into a level wall. Or rafters, stairs, or structural blocking. I'm too picky....
PS- don't forget the sill sealer or termite shield if required.
Gary
Old 04-29-2011, 09:47 PM   #7
Framing Contractor
I see it all the time with addition. If I show up at an addition and the siding and sheathing isn't ripped off down to the framing, I know right there that there will be a problem because how can the mason possible get the height right without opening uip the wall. Yiou can't just assume if your using new 2x10's and the existing are 2x10's that you can make the new fouindation the exact same height...doesn't work that way. Mnay old homes a 2x10 can measure 9" or 9-1/8".
Where I'm from conventional lumber 2x10's measure 9-3/8-9-1/2". There is a slight variation and they will shrink. I-joists they are exactly 9-1/2" and don't shrink. You have to figure the height of the new joists, the double plate thickness or single plate and the sill sealer thickness to determine the finished foundation height when match the top of existing floor joists. That is the most important thing.
Alot of times the new joists are taller than the existing joists and I've seen foundations the same height...there begins the problem. You are better of with the foundation being a little lower than higher because you can always add a piece of 1/4"..1/2" piece of plywood to the top of the sills need be.. Being to high you have problems.
Joe Carola
Old 04-29-2011, 10:03 PM   #8
Registered User
Well, if we're giving them both barrels..... page 49-52, ; http://books.google.com/books?id=iwS...rafter&f=false
Though I wouldn't cut the sub-floor...
http://www.paintsource.net/pages/sol...ood_shrink.htm
http://www.buildingscience.com/docum...d-but-strange/
Gary
Old 04-29-2011, 10:03 PM   #9
Thanks for all of your replies.
The new construction will be added to the old house and its walls, floors and joists/headers will be exposed for exact height measurments.
In reply to one post- I have always covered the block foundation with the same size sills. The engineered I joists will lay on the sills and need that space for support.
I guess I could use 2x4 sills where the joist rims on the two other sides are, but have never done that.
Old 04-29-2011, 10:17 PM   #10
Rewards Points: 86
Of coarse it can make a difference but this are things you deal with in the field as they present themselves.
You don’t "plan" for an 1/8” that you don’t even know exist until your staring at it.
Old 04-29-2011, 10:25 PM   #11
Termite shield
Just a bit of information- I checked Home depot, Lowes and
Menards for termite shield. Not one carried it.
I guess i could use 10" sheetmetal flashing and bend down the edges later. It would look better if it came with a factory bend thats uniform.
Old 04-29-2011, 10:38 PM   #12
Framing Contractor
Not for me. I do plan because I know that all pt measures 1-9/16" to 1-5/8" before I even get it. Nailing 2 together which is what we always use measures 3-1/4" by the time your done nailing together. It's been like that for the past 25 years or so. Sill sealer hasn't changed it's thickness either. So I know ahead of time what to figure, I don't have to have the material in front of me staring at it first.
Joe Carola
Old 04-29-2011, 10:55 PM   #13
Rewards Points: 86
1 9/16” to 1 5/8” x2, that’s 3 1/8” to 3 ¼” a difference of 1/8”. How do you plan for the 1/8” until you’re staring at it? Give me a break framer.
Pressure treated wood does or does not need to be painted???? stanlam Building & Construction 11 03-27-2011 04:04 PM
Home depot vs lowes pressure treated wood Docs911 Building & Construction 1 03-14-2011 11:30 AM
Okay to wash wood treated with jasco termin-8 wood preservative? darsunt Painting 1 12-29-2009 04:02 PM
Best way to attach pressure treated wood to painted siding ? 1freebird Building & Construction 1 09-30-2009 11:02 PM
galvanized bolts for pressure treated wood? Jeremy Hillary Boob, PhD Building & Construction 11 07-10-2009 10:53 AM
