Pressure-treated Wood For Deck Joists? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 01:20 PM   #16
Hi;
I am a professional deck builder in Washington state and have been building decks for 20 years. Pressure treated wood in necessary for all framing of a deck otherwise it will rot out in 5+years. I replace decks all the time where non-treated wood was used.
Good Luck
Rod
rnj0094 is offline   Reply With Quote
Old 02-26-2013, 08:27 PM   #17
Rewards Points: 320
Since you're going to use the treated lumber, you must make sure that all fasteners and supports, nail, bolts, hangers, connectors, flashing, whatever, have to be rated for contact with current chemicals for treatment or fasteners don't directly contact the wood, using epdm membrane or such. Standard is hot, double dipped galvanized fasteners and hangers. Regular joist hangers, for example, will corrode faster. The chemicals in the treated lumber is very corrosive to metals and you might as well use the cedar if fasteners are wrong kinds. If hidden deck fasteners are used, make sure the instruction says they will not corrode if in contact with PT. Coated nail gun nails are the worst. Do not allow the deck to be finished with nail gun nails.
carpdad is offline   Reply With Quote
Pressure Treated Wood-Direct Ground Contact Randell Tarin Building & Construction 14 10-14-2011 10:52 PM
Bottom plates are not pressure treated Richo Building & Construction 10 03-16-2009 06:48 PM
garage sill is not pressure treated danz Building & Construction 14 02-21-2009 09:25 PM
ceramic ove pressure treated Gery Flooring 3 04-06-2008 12:33 PM
Don't use these nails on treated wood? scarrell Carpentry 3 04-01-2006 11:41 AM
