Pressure Treated Wood Color - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-15-2012, 09:11 PM   #1
Rewards Points: 518
Pressure treated wood color
Just finished putting up a fence built entirely with pressure treated wood. Even though all of the lumber came from the same supplier tied to the same bundles, the color variation is insane! Some is dark green like usual however almost all of the 1x6 fence boards are completely yellow! We thought they screwed up and sent us spruce but they are all individually marked stating they are pressure treated, are wet to the touch and juice when screwed into them. I've just never seen what I would call "clear" pressure treated boards before?
n0c7 is offline   Reply With Quote
Old 07-15-2012, 10:17 PM   #2
Rewards Points: 2,210
Unfortunately the colour can be all over.
Never seen it clear, usually really light green to dark green.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
n0c7 (07-16-2012)
Old 07-15-2012, 10:19 PM   #3
Rewards Points: 13,300
All depends on how it was stored. Outside the bundles will be dryer then the inside.
After a few years it will all even out.
n0c7 (07-16-2012)
Old 07-16-2012, 12:56 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,146
All the stuff HD carries now is brown....
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
n0c7 (07-16-2012)
Old 07-16-2012, 02:00 AM   #5
Rewards Points: 518
The green ones I believe are coated with amine copper quat (ACQ) and the yellow looking ones say copper azole (CA).
Old 07-16-2012, 02:06 AM   #6
Used to get brown stuff, called cedar-tone
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Pressure Treated Wood chronojosh Building & Construction 3 04-12-2012 08:19 PM
Best way to attach pressure treated wood to painted siding ? 1freebird Building & Construction 1 09-30-2009 11:02 PM
Pressure treated wood deck / cuprinol Dfigtree Flooring 3 04-03-2009 07:04 AM
Comment on those Special Type of Treated Wood for Deck ? KUIPORNG Landscaping & Lawn Care 4 07-04-2006 01:38 PM
