Pressure Treated Posts In Soil - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-19-2007, 06:17 AM   #1
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Pressure Treated Posts in Soil
Ran across this in "Remodeling" magazine. "Post and Pole membrane cover" for wrapping posts set into soil. Thought I'd share it, since there have been discussions about fence posts and also Pole barn posts ...
http://www.mfmbp.com/ccp51/media/ima...%20graphic.jpg
http://www.ebuild.com/articles/artic...ticleId.532677
http://www.smarthomeowner-digital.co...0070708/?pg=21
http://www.mfmbp.com/ccp51/cgi-bin/c...p&cat=&catstr=
- Build Well -
Old 07-19-2007, 01:07 PM   #2
Custom Cabinet Maker
Atlantic; Interesting guess Grace will be happier Presume good ole ICE & Water be the same thing
skymaster is offline   Reply With Quote
Old 07-19-2007, 01:23 PM   #3
Rewards Points: 528
They are interesting. But here in Philadelphia, Post's are now required to be placed on top of a concrete pier with a post bracket anchored to the pier.
I just had my 6 by 6 posts replaced a year ago because dryrot formed on the area exposed just above the old concrete line. My best guess that I must have had 20% of both posts that were affected. I discovered it by accident when I decided to do some touch up staining on them. I would have expected the dryrot to form below the concrete line but that was not the case.
rjordan392 is offline   Reply With Quote
Old 07-19-2007, 02:31 PM   #4
concretemasonry's Avatar
Rewards Points: 2,626
The critical area is about at the soil level where the moisture content varies, tearing the wood apart. Smae thing for piling in the ocean and lakes at the water line.
If you look closely in one of the links, the wrap is not deep, but at the ground level.
Even if you set wood in concrete, you must keep the top of the concrete (and bottom of the posts) above ground level and shed water from the top of the concrete.
concretemasonry is offline   Reply With Quote
Old 07-20-2007, 06:47 PM   #5
Hmmm. I wonder if the same can be achieved by bitumen paint??
Paul
Priemsy is offline   Reply With Quote
Old 07-20-2007, 07:02 PM   #6
fhi vinyl windows
fhivinylwindows's Avatar
Rewards Points: 150
A bit on the pricey side I was looking at the product the other day.
fhivinylwindows is offline   Reply With Quote
Old 07-22-2007, 12:01 PM   #7
This is costlier but it surely an effective way
citybuilder is offline   Reply With Quote
Pressure treated posts set in concrete? zubin6220 Building & Construction 19 08-13-2013 05:39 AM
Shoddy Pressure Treated Lumber? spanky77 Building & Construction 17 06-25-2011 08:09 AM
Pressure treated wood - attracts bees? mcvane Carpentry 4 08-31-2007 08:43 AM
use of pressure treated wood in the garden bscout Landscaping & Lawn Care 7 06-06-2007 11:23 PM
pressure treated or pre-stained?? farrington135 Landscaping & Lawn Care 2 05-03-2007 09:04 AM
