Pressure Treated Lumber Problems - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 07:41 PM   #16
Registered User
Rewards Points: 5,516
Check with your local AHJ. You could get by with a foil-faced (PIC) foamboard (possibly XPS, if thick enough) under a regular kiln-dried plate, many locales permit it, #3: http://publicecodes.cyberregs.com/ic...9_3_sec017.htm
It would act as the air/thermal/capillary break from the earth under the slab. The 2x3's are fine up to 10' tall; "R602.5 Interior nonbearing walls. Interior nonbearing walls shall be permitted to be constructed with 2-inch-by-3-inch (51 mm by 76 mm) studs spaced 24 inches (610 mm) on center or, when not part of a braced wall line, 2-inch-by-4-inch (51 mm by 102 mm) flat studs spaced at 16 inches (406 mm) on center. Interior nonbearing walls shall be capped with at least a single top plate. Interior nonbearing walls shall be fireblocked in accordance with Section R602.8." From IRC; http://publicecodes.cyberregs.com/ic...002_par011.htm
Or IBC: http://publicecodes.cyberregs.com/ic..._23_par201.htm
Gary
Tags
2x3 , framing , plate , stud , wall
Pressure treated wood does or does not need to be painted???? stanlam Building & Construction 11 03-27-2011 03:04 PM
pressure treated, big box vs lumber yard ugabulldog Building & Construction 4 10-09-2010 02:16 PM
Treated lumber secutanudu Painting 5 09-11-2010 11:51 AM
Where to buy heat treated Plywood or OSB and lumber? Spud General DIY Discussions 5 10-21-2009 09:49 PM
Pressure Treated Decking Broncosfan1983 General DIY Discussions 2 09-13-2007 07:12 PM
