Old 06-17-2008, 02:53 PM   #1
Question
Pressure Treated Lumber for Basement?
Is pressure treated lumber really needed for a bottom plate? I'm wanting to create a curved wall which I will do the top/bottom plates out of 3/4" plywood. Not sure if Home Depot/Rona has 3/4" Pressure treated Plywood?
Can I just use standard 3/4" plywood?
If not, what would work for this curved wall?
matt
mfleming is offline   Reply With Quote
Old 06-17-2008, 03:08 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I do believe, that HD carries Pressure Treated 3/4" plywood. If not, a lumber supply company should have it.
- Build Well -
Old 06-17-2008, 03:14 PM   #3
Another option: use adjustable steel track.
- Build Well -
Old 06-17-2008, 04:44 PM   #4
Moderator
Termite's Avatar
Good option.
Yes, it has to be treated lumber. You can get ACQ treated plywood, but you'll have to go to a lumberyard. I don't think most box stores have it.
Old 06-18-2008, 01:33 AM   #5
My house is only a year old and the builders installed the framing and insulation around the perimeter. They used 2x3 and no pressure treated bottom plate. Should I rip down everything around the exterior and install a pressure treated piece or is using that sill gasket foam (white thin stuff) under the bottom plate and over the concrete going to be fine?
Old 06-18-2008, 09:43 AM   #6
Moderator
Termite's Avatar
If you can isolate the untreated lumber from the concrete, you'll be ok. Foam sillsealer like you described should work well, provided you can get it in there.
Shoddy Pressure Treated Lumber? spanky77 Building & Construction 17 06-25-2011 09:09 AM
How do you tell the diff btw Pressure treated and regular hardwood zhbuyi Carpentry 3 06-08-2008 08:11 PM
Help! My pressure treated lumber is warping! jrepp Building & Construction 5 10-31-2007 04:15 PM
pressure treated or pre-stained?? farrington135 Landscaping & Lawn Care 2 05-03-2007 10:04 AM
