-   -   Pressure Treated Lumber for Basement? (http://www.diychatroom.com/f19/pressure-treated-lumber-basement-22405/)
mfleming 06-17-2008 02:53 PM
Is pressure treated lumber really needed for a bottom plate? I'm wanting to create a curved wall which I will do the top/bottom plates out of 3/4" plywood. Not sure if Home Depot/Rona has 3/4" Pressure treated Plywood?
Can I just use standard 3/4" plywood?
If not, what would work for this curved wall?
matt
AtlanticWBConst. 06-17-2008 03:08 PM
I do believe, that HD carries Pressure Treated 3/4" plywood. If not, a lumber supply company should have it.
AtlanticWBConst. 06-17-2008 03:14 PM
Another option: use adjustable steel track.
Termite 06-17-2008 04:44 PM
Good option.
Yes, it has to be treated lumber. You can get ACQ treated plywood, but you'll have to go to a lumberyard. I don't think most box stores have it.
mfleming 06-18-2008 01:33 AM
My house is only a year old and the builders installed the framing and insulation around the perimeter. They used 2x3 and no pressure treated bottom plate. Should I rip down everything around the exterior and install a pressure treated piece or is using that sill gasket foam (white thin stuff) under the bottom plate and over the concrete going to be fine?
Termite 06-18-2008 09:43 AM
If you can isolate the untreated lumber from the concrete, you'll be ok. Foam sillsealer like you described should work well, provided you can get it in there.
