Pressure Treated Deck Posts In Concrete Pillar? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-18-2012, 02:11 PM   #1
Pressure Treated Deck Posts in Concrete Pillar?
Thinking of setting deck posts in concrete. 48" frostline. Can use tubes to ensure concrete is well above soil or crushed stones under deck. Would it help to wrap the timbers in plastc (below ground level?
Nick914 is offline   Reply With Quote
Old 06-18-2012, 05:20 PM   #2
DIY staff
Rewards Points: 7,174
Do not set the posts in concrete--they rot--cast a pier,using a sonotube--embed a post anchor into the wet concrete--
Buried posts do not meet modern code in most areas--
mae-ling (06-24-2012)
Old 06-18-2012, 05:20 PM   #3
Framing Contractor
Why would you not sit them on top?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 06-20-2012, 01:33 PM   #4
Rewards Points: 850
you set them on top so they can wiggle all over the place in a few years. i set mine in concrete, there not going anywhere then. i have used the big metal brackets that attach to the pose then go in the concrete about 1'. but i think the old tested true method of setting them in concrete works best for strength. what ever works for you and you feel the safe-fest with.
hotrod351 is offline   Reply With Quote
Old 06-24-2012, 01:30 AM   #5
Framing Contractor
Originally Posted by hotrod351
you set them on top so they can wiggle all over the place in a few years. .
Explain that.
Joe Carola
The Following User Says Thank You to Joe Carola For This Useful Post:
oh'mike (06-24-2012)
Old 06-24-2012, 06:53 PM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
Your anchor rod goes in the wet concrete when wet then your bracket.
JetSwet is offline   Reply With Quote
Old 06-24-2012, 07:03 PM   #7
Rewards Points: 12,868
http://strongtie.com/products/connectors/PB-PBS.asp
Old 06-24-2012, 07:14 PM   #8
Rewards Points: 1,294
My pool deck has been sitting on concrete piers for 12 years now and they have not loosened up and wobbled around one bit. I have also built about 50 decks for customers the same way over the years and never had a callback to fix any problems.
I have repaired decks in the past that had the wood post set into concrete. The last one I did a couple years ago had 8 treated posts set ito 8" sono tubes. Every concrete pier was cracked from the corners out and most of them had rotted enough that they had to be replaced
danpik is offline   Reply With Quote
Old 06-25-2012, 10:56 AM   #9
Rewards Points: 31
Another vote for doing it the proper way by setting j bolts deep in the concrete footings with bracket on top. Keeps the wood 1" off the ground so it doesn't rot or wick standing water.
thetalkingmule is offline   Reply With Quote
Concrete Patio Enclose with Pressure Treated Wood ryanb4614 Concrete, Stone & Masonry 8 04-23-2012 07:22 AM
setting aluminum railing posts in 6"x6" pressure treated landscape ties. remdel4lesbyric Building & Construction 1 05-19-2011 06:51 PM
Fixing out of square deck posts Starbuck II Building & Construction 23 05-03-2010 12:02 PM
6x6 deck posts to concrete slab csiryan Building & Construction 10 11-16-2009 09:28 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
