Originally Posted by Yoyizit
I thought they used a barrier, either tarpaper or plastic, with untreated wood. . .?
Might be possible some places, but my Inspector would expect to see PT as the bottom plate
Even with sill gasket below the PT
Many splits have finished basement & PT bottom plate is used
Builders here don't use a sill gasket that I have seen
Every beam I have ever seen in a concrete pocket has PT under it
Seems every basement build I have seen on here someone asks if the bottom plate is PT
With the change in chemical treatment the PT can look almost like reg wood
