Pressure Treated, Big Box Vs Lumber Yard - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 08:31 PM   #1
Rewards Points: 276
pressure treated, big box vs lumber yard
I know there is a difference in 5/4" boards, what about 2"x's and 6"x6"'s? (quality & color)
ugabulldog is offline   Reply With Quote
Old 10-09-2010, 06:33 AM   #2
Usually also a difference in price, local lumberyard is less expensive, and usually better quality.
Old 10-09-2010, 11:02 AM   #3
The difference, other than price, is whether it is #1 or#2 which is a cosmetic difference in the number of defects. Shop around for prices. I never use treated lumber for decks any more. A comparable/cheaper wood alternative would be stk cedar even though it needs more maintenance.
mrgins is offline   Reply With Quote
Old 10-09-2010, 12:20 PM   #4
Registered User
Rewards Points: 526
There are different structural grades as mentioned, appearance is a minor factor, span distance critical. Cedar can be used for a deck surface, not framing structurally with most Building Departments due to it's low structural rating.
What is the application?
Gary
Old 10-09-2010, 02:16 PM   #5
Rewards Points: 276
I am going to buy from lumber yard,....deck already has all framing materials from there, just going to build railing and I want it to match...
Where to buy heat treated Plywood or OSB and lumber? Spud General DIY Discussions 5 10-21-2009 09:49 PM
Best way to attach pressure treated wood to painted siding ? 1freebird Building & Construction 1 09-30-2009 10:02 PM
pressure treated lumber - Painting Question slim one Painting 1 05-05-2009 06:35 PM
regular zinc coated steel hardware with ACQ treated lumber dumbunusedid Building & Construction 3 08-12-2008 07:20 PM
Galvanized Flashing with ACQ Treated Lumber? Ler0y Jenkins General DIY Discussions 5 05-18-2008 10:59 AM
