Pressure Treated 2x4's - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-16-2010, 02:51 PM   #1
Rewards Points: 640
pressure treated 2x4's
I just got my shipment of pressure treated 2x4's today for my basement project (bottom plate is PT) while stacking them in the garage, I noticed some are very light like a normal 2x4... but some are very heavy, almost like they are full of water... do these retain water if the lumbar yard stored them outside? should I let them sit indoors for a while before using them? I'm not getting to the wood construction for a week or so, would that be enough "drying" time to aclamate to the indoors?
BlueBSH is offline   Reply With Quote
Old 08-16-2010, 03:22 PM   #2
Rewards Points: 5,336
Sounds like you received a mixed batch. The light ones have been around awhile and the heavy ones are new. It will take a few weeks for the heavy ones to dry out.
Ron
Old 08-16-2010, 03:24 PM   #3
Rewards Points: 640
Ron
Is it ok to use them before they dry out? I'm just anchoring them to the concrete then framing on top of them
Old 08-16-2010, 05:21 PM   #4
Nobody ever waits for them to dry out. Best to secure them before they start to warp.
Ron
Old 08-16-2010, 06:06 PM   #5
Registered User
Rewards Points: 526
Use some sill sealer under each against capillary action and for a thermal break from the slab/wall. P.t. wood is not waterproof, unless you special ordered it as such. Nail tight to foam board on concrete, no gap to create convective loop behind the glass batt in the wall. Fire-code requires blocking every 10' laterally. http://www.greenbuildingadvisor.com/...-building-code
Be safe, Gary
Old 08-16-2010, 07:43 PM   #6
Rewards Points: 640
Be safe, Gary
Already got the sill gasket foam (the stuff on a roll the width of the 2x4 that is about a 8th of an inch thick I think?) ready for that when I get to it. thanks for the blocking tip, didn't have it in my plan
Old 08-16-2010, 08:56 PM   #7
Remodeling Contractor
Use them as soon as you can, don't wait for them to dry out. As pt lumber dries, it can warp and twist DRAMATICALLY.
eisert is offline   Reply With Quote
Old 08-17-2010, 04:43 PM   #8
Rewards Points: 502
the local lumber yard rachet straps and hoses down the PT after hours to keep it from warping.
if it warps on you dramatically, you can probably take it back and get usable boards.
forresth is offline   Reply With Quote
Shoddy Pressure Treated Lumber? spanky77 Building & Construction 17 06-25-2011 08:09 AM
Pressure treated buck boards for door ? Mudball Building & Construction 9 04-14-2010 08:00 PM
Hybrid Deck - Is Pressure Treated + Composite Feasible? kyassassin Building & Construction 4 01-15-2009 08:33 PM
How do you tell the diff btw Pressure treated and regular hardwood zhbuyi Carpentry 3 06-08-2008 07:11 PM
pressure treated or pre-stained?? farrington135 Landscaping & Lawn Care 2 05-03-2007 09:04 AM
