Old 11-24-2009, 01:26 PM   #1
dIYHell
prepping a fireplace surround for tile
I have a directvent fireplace installed in surround that's currently constructed out of 2X4's I was wondering whats the best way to prep this for tile. Since the fireplace extends about 5/8ths from the 2x4s I was thinking of using 1/4 cement board? If I use this do I tape the seams? Anybody have good suggestions for webs sites for installing backing and tile?
rocketdoctor is offline   Reply With Quote
Old 11-26-2009, 12:27 AM   #2
Moderator
Termite's Avatar
I'd suggest 1/2" backerboard. 1/4" is only for floors unless there's a plywood substrate on the wall you can screw it to. Taping the seams with fiberglass backerboard tape and mudding with thinset is good practice to prevent cracking at seams.
Check out the Tile Council of North America's website. You can download their tile installation guidelines as I recall, and it is very informative.
Old 11-26-2009, 10:29 AM   #3
Wolf
Thekctermite is right on. I used a stone product from Natural Stone Veneer International (nsvi.com) for my fireplace and the backer was 1/2" Durock cement board fastened to the framing with Durock screws. All joints were taped and covered with the same thinset mortar used to adhere the stone to the Durock. Complete instructions can be found at http://www.nsvi.com/NSVI_Installation_Guide.pdf
Follow the instructions for interior installations. Good luck with your project.
ralphfravel is offline   Reply With Quote
Old 11-30-2009, 11:53 PM   #4
dIYHell
thanks for the info, I'll need to use 1/4 inch board to keep the tile from extending too much past the fireplace. I'll put a few more studs in the surround framing to support it good. thanks for the tiling guides.
Removing Granite & Omni Grip Adhesive from Fireplace Surround RayJak Tiling, ceramics, marble 4 11-13-2009 04:28 PM
Fireplace surround tiling Ducowti General Discussion 8 10-28-2008 10:16 AM
Fireplace Surround Remodel baksdak Project Showcase 5 03-06-2008 01:28 PM
