Preparing A Little For Future Swing Project - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-21-2014, 03:58 PM   #1
Rewards Points: 514
preparing a little for future swing project
Since I successfully completed a playset with a slide for my kids a couple weeks ago I want to get stuff ready for when I want to add the swings (when it's warmer) My plan is to get a 12' 4x4 and attach it to the top front corner of the guard rail 4x4 post and then attach the other end to an A-frame. I plan to get 2 10' 4x4s for the a frame and not bury/concrete them at all. I found these brackets on HD website that look almost to good to be true. They are for attaching the tops of the 4x4s at the right angle for an a frame without having to cut them at angles. Any experience with these? I'd of course get 2 and I plan to over hang the top post by about 2' for a baby swing.
http://m.homedepot.com/p/Swing-N-Sli...510/100038887/
How should I attach the other end to the top of the playset? I was thinking 2 straight brackets for the out side and inside edge, and a 90 degree for under the swing beam attaching to 4x4 post from guard rail.
nikeman is online now   Reply With Quote
Old 11-21-2014, 04:28 PM   #2
Rewards Points: 1,614
That bracket looks a bit thin to me, but I tend to over build everything.
I would try to use corner reinforcements for the attaching the 4x to the slide set instead of the straights, then use the 90 degree for the underneath.
ED
de-nagorg is offline   Reply With Quote
Old 11-21-2014, 04:40 PM   #3
Rewards Points: 514
ED
Something like this ?
Old 11-21-2014, 04:43 PM   #4
Yes, that'll get it.
ED
Old 11-21-2014, 04:45 PM   #5
Rewards Points: 514
Also looked at the 4x4 half base. I could attach it to the top of the front corner 4x4 and then attach both sides to the swing post. Not sure how sturdy that would be though.
Old 11-21-2014, 05:22 PM   #6
Try this site for a sturdier looking A frame bracket, they also have more things for swing sets.
http://www.swingforswingset.com/Swin...meBracket.aspx
ED
Steel Swing Set, Post Frame wehomama Building & Construction 1 08-02-2013 09:34 AM
support for tire swing or porch swing Ewalker Building & Construction 3 05-09-2013 09:23 PM
Drywall project: New basement bathroom NetTractorTalk Drywall & Plaster 15 10-03-2012 01:23 PM
my floor refurbish project Knucklez Project Showcase 28 08-10-2010 09:14 AM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
