Preparing Concrete Block For Stone Veneer - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 05:16 PM   #1
Rewards Points: 508
Preparing concrete block for stone veneer
As I started to strip paint with my pressure washer the other day. I noticed that under the paint, I seem to have two skim coat layers on the block; at least the white stuff in the picture feels abrasive like mortar and it crumbles like a masonry product. Is stripping the paint alone sufficient to achieve an acceptable bond? Should I try to strip away the white stuff before I apply the cultured stone veneer? Should I try to strip away both layers of mortar to expose the concrete block?
benjamincall is offline   Reply With Quote
Old 05-31-2011, 06:15 AM   #2
Rewards Points: 1,580
I would think that anything loose will need to come off; the mortar won't stick for long to a failing substrate.
bob22 is offline   Reply With Quote
Old 05-31-2011, 06:48 AM   #3
Stay-at-home GC
Not sure how long Surface Bonding Cement has been around but I think this is something people are going to have to start thinking about before stripping mortar and other finishes from block.
I guess a mortar joint between each block would be the quickest way to tell if you are dealing with a traditionally built wall or these new Quikwall drystack versions.
If it is SBC (unlikely but becoming more common) you definitely don't want to remove it, as it is structurally significant.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 05-31-2011, 07:47 AM   #4
Rewards Points: 508
This isn't surface bonded block. That thin layer of white mortar stuff only came off when I used a 3500 PSI 4 GPM pressure washer with the nozzle pressed right up to the surface. I'm thinking all I'll need to do is remove the paint and adhere the veneer directly to the white stuff (no lath).
Old 06-01-2011, 08:19 AM   #5
Rewards Points: 508
This is from the installation guide from GAF for their CanyonRock manufactured stone veneer:
Preparing concrete block for stone veneer-how-prepare-concrete-block-stone-veneer.jpg
concrete block house shower medalta Building & Construction 3 11-02-2011 05:16 AM
Bathroom Remodel - Resurfacing Plaster over Concrete Block itcanadian Remodeling 2 05-30-2011 10:10 AM
building concrete steps cinder block frame? drewhart Building & Construction 2 06-10-2010 01:48 PM
concrete block christoff Off Topic 2 06-07-2010 06:00 AM
Concrete Block under the Front Door Robinjail Building & Construction 1 06-27-2006 10:04 PM
