Preparing A Base For A Shed With A Wooden Fllor. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-03-2011, 12:41 PM   #1
preparing a base for a shed with a wooden fllor.
Will a layer of pea gravel be sufficient base for a shed with
a wooden floor.
Ingrid Cockburn is offline   Reply With Quote
Old 09-03-2011, 06:07 PM   #2
I would use min 3 in
dvatt is offline   Reply With Quote
Old 09-03-2011, 06:59 PM   #3
Rewards Points: 1,506
Choose an area that does not collect water. This is almost intuitive, don't put the shed in a low area. The carved out bed into which you will pour the gravel must be above the water table.
You will probably hav joists for the shed floor just like a floor in a house. Any wood that touches the ground or stone or concrete should be pressure treated.
Old 09-04-2011, 05:57 AM   #4
Rewards Points: 27
I would suggest adding a heavy plastic (6-mill) on the ground before putting down the gravel.
MBatson is offline   Reply With Quote
Old 09-04-2011, 12:22 PM   #5
Landscaping fabric to allow water through thick plastic will cause water to sit and could lead to future rotting of the 4 x 4 skids
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
Drainage for Plastic Shed on Wooden Platform AikiPapi Building & Construction 7 07-29-2010 11:35 AM
Concrete base for shed vespa Landscaping & Lawn Care 0 06-20-2010 04:06 PM
How to create a curved wooden base shoe? hayzen Carpentry 3 07-28-2009 03:29 PM
Base Structure for Shed jasoncw Building & Construction 4 04-16-2009 07:08 AM
