Prehung Door Rough - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-26-2009, 08:42 PM   #1
prehung door rough
I am roughing a 24" prehung door. I have 26" wide X 82" high.
I'm running into a problem with my header. The frame goes off 1/2" between the 2 jack studs. I noticed this when checking with a level. Should I fix this by adjusting the jack stud to accomodate the 1/2", or by shimming within the pre hung frame?
Thanks.
sharp is offline   Reply With Quote
Old 12-27-2009, 06:44 AM   #2
Remodeling Contractor
you do not need to shim or nail the head jam to the studs. The trim is enough hold. This way when the header moves it does not knock your door out of whack. So the answer is .... do not worry about the uneven space above the jam, but do level the jam perfectly.
Old 12-27-2009, 06:53 AM   #3
Thanks.
Installing prehung door jdhar Carpentry 9 10-22-2009 08:21 AM
can u buy a prehung door for a 21\2 framed wall ron0805 Carpentry 2 10-07-2009 09:10 PM
Cutting prehung doors narrower? perpetual98 Building & Construction 2 04-14-2008 10:43 PM
Prehung entry door gap problem 1fstws6 Building & Construction 3 03-21-2008 07:45 PM
