Preferred Method For Attaching Soffit And Fascia? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 12:29 AM   #1
preferred method for attaching soffit and fascia?
I'm replacing all the soffit and fascia on my house. For the soffit I've used an air stapler in the past but won't have access to one this time. What size/type of screws do you prefer to attach soffit?
Fascia, what's your preferred fastening method? I've seen guys that face nail, and I've seen guys that use screws from the bottom. If screwing from the bottom what size/type of screw? Do you still face nail at the seams to prevent wind from catching, no face nails at all?
Yeti is offline   Reply With Quote
Old 03-09-2013, 12:54 AM   #2
Rewards Points: 12,858
Got any pictures.
What material are you using?
I've never seen anyone use a stapler or screws is this is just plywood and 1 X's, just galvinized ring shank nails. I like to use siding nails due to the smaller heads.
Old 03-09-2013, 09:08 AM   #3
Rewards Points: 150
Agree with joe. What material t u using sheet metal over wood, wood ? Vinyl PVC material
kaschmid3 is offline   Reply With Quote
Old 03-09-2013, 10:18 AM   #4
Sorry, using aluminum soffit and fascia over wood.
Old 03-09-2013, 10:19 AM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,006
galvy roofing nails for the soffit with the odd stainless steel ring shank cladding nail to prevent sag. . with stainless ring shank nails in the coil stock fascia
woodworkbykirk is offline   Reply With Quote
Old 03-09-2013, 10:21 AM   #6
Rewards Points: 125
I'd usually prefer that someone else take care of it for me, but I rarely get that choice
ThatDaveGuy is offline   Reply With Quote
Old 03-09-2013, 10:31 AM   #7
Roofmaster
Rewards Points: 2,172
I just used my Hitachi pneumatic stapler for this task and it went like a breeze. Plated 1.25 Bugle head screws would work well too on a cordless light weight drill.
I bought the little Bosch 12.5 volt drill and I am absolutely amazed by the torque this thing has. couple that tool with the Bosch Magnetic bit holder and you are good to go, or buy a pneumatic stapler. The advantage of the screw obviously being easy removal. The Bosch mag bit holder holds bugle head (Multi Purpose) screws square to the work and firm. Well worth the money.
No, I don't sell Bosch Tools, but I do own a mess of them cause they are damn good.
Old 03-09-2013, 08:43 PM   #8
Still no picture?
I have not seen aluminum soffit used for many years.
Does it have oval shape holes where the nails go?
Aluminum soffit needs aluminum nails not steel or it will corrode.
I only use stainless steel trim nails.
If I had a picture I could suggest a way to install the fashi so it will not buckle.
Old 03-09-2013, 11:27 PM   #9
Rewards Points: 920
I nail up the soffit with stainless ring shank nails. Have also used roofing nails in the past.
The alu fascia I nail up with roofing nails after pre-drilling. I got so goddamned tired of those alu nails that I just use roofing nails because it is getting gutter on top anyway. If I had a gable end, I would use the alu nails and pre-drill deeply.
cleveman is offline   Reply With Quote
Old 03-09-2013, 11:37 PM   #10
Rewards Points: 83
how wide is the soffit 12", 24" if you have f-chanel against the wall and your going to cover in with al fascia you could use 1/2" staples in a stable arrow gun. done it many times never had any issues.
mech_gui is offline   Reply With Quote
Question about replacing fascia and soffit paneling creamaster Carpentry 2 03-31-2010 10:01 PM
Vinyl soffit and fascia msyv Building & Construction 7 09-13-2009 11:21 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 08:47 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
