Old 07-28-2009, 09:59 PM   #1
cj
Default Precast concrete footing.
Does anyone know a manufacturer/distributor of precast concrete footings as in the pic.
Discussed at http://www.homeconstructionimproveme...-pier-footings
cjf1980 is offline   Reply With Quote
Old 07-28-2009, 11:55 PM   #2
concretemasonry's Avatar
That depends on where you are. That is not new, but a rare product because of the weight and not a competitive method and has never taken off. Because of the volume and shipping, it could be expensive.
Check the net to see where the suppliers are and they could give you pricing and shipping costs.
It will require a different method of construction, more height control and possibly different post connections.
Dick
concretemasonry is offline   Reply With Quote
More On This Topic
Part 2 - Learn how to adjust the guitar string action to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
Part 2 - Learn how to adjust guitar pickup height to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
Part 1 - Learn how to adjust guitar pickup height to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
Now, I'm going to show you some options you could use your spheres. One of them is to create a finial. What I have here it's a precast part of a column crown and it has a circular area, so you could just set the sphere on top of it or mortar it, or you... Read More »
The cost of an elliptical trainer, which ranges from about $300 for a bare-minimum, unpowered machine to more than $2,500 for the top of the line, may not fit into your exercise budget. This barrier to ownership does not mean that access to the... Read More »
concrete footing for deck rcassidy Building & Construction 2 06-22-2009 04:49 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 10:21 AM
Shop concrete pad with 42" footing? deck99 Building & Construction 6 03-13-2009 03:32 PM
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 33 03-08-2009 10:30 PM
Concrete patch for lally column footing? AllGoNoShow Building & Construction 6 10-21-2006 10:16 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
