Old 03-25-2010, 10:52 AM   #1
Pre sub floor inspection?
What is this? I got the footer dug and am waiting for the inspector to come by but on the inspection sign off it has the next inspection is Pre sub floor. I know what the sub floor is(the framing that one would nail the flooring to.) but is pre sub floor after i pour the concrete footer? but before i begin to frame?
Thanks for any input.
Axe McGee is offline   Reply With Quote
Old 03-25-2010, 02:18 PM   #2
I suspect that's an inspection of the girders and joists. Subflooring is I believe considered the underlayment (plywood or whatever) over which the finished floor is installed.
Old 03-25-2010, 02:36 PM   #3
I have gas!
Clutchcargo's Avatar
Platform construction is typical, isn't it... you build a deck with subfloor, then build walls on top of that, add joists on top opf that followed by subfloor, and then walls again, etc. Pre-subfloor doesn't make sense, unless the inspector wants to see the joists before the deck goes down.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 03-25-2010, 02:48 PM   #4
Xtreme DIY'r
Call your Inspector, they will be able to tell you what they want to see
Old 03-25-2010, 05:53 PM   #5
Moderator
kwikfishron's Avatar
They just want to see your joist job before you cover it up.
kwikfishron is online now   Reply With Quote
Old 03-25-2010, 07:10 PM   #6
probably looking for proper bolts/ fasteners for your foundation plate which your framing will sit on
The older I get the better I was
Old 03-26-2010, 06:42 AM   #7
I caught up with the inspector when he got here for my footer inspection. He said it was before the joists get covered up. They want to see the framing of the joists and the strapping that holds the whole gizmo down.
Thanks a ton for the replies everyone. :D
