Pre-painted Vs. Primed Hardie Plank - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-23-2007, 02:41 PM   #1
Pre-painted vs. primed hardie plank
I am going to reside with Hardie over my T1-11. I can not decide between the prepainted or the primed. The price of the prepainted is not much more and the labor rate is the same. I know I could not paint my house for the price difference. I would have to do 1/2 the house myself to barely break even is my guess. Can someone tell me the pros and cons of prepainted vs. primed and which I should do. Thanks
Todd1 is offline   Reply With Quote
Old 08-24-2007, 06:03 PM   #2
Definitely go with the prepainted. They do a nice job and the paint is guaranteed. Each piece is covered with a piece of peel off plastic for protection. There is no way you could paint the primed Hardi for this low a cost. I checked with Sherman Williams and the paint was about $26. per gallon which would cover approx. 300 square feet. How long is it going to take you to paint the house when you finish siding? I just ordered 8 square down in Virginia. Primed was $108. per square. Painted was $154. per square. It was shipped and recieved 5 days after order direct.
Also order the caulk from them. It is color matched to the siding. I ordered a tube per square, but I think a tube per 2 square would be enough. The cauld was $8.00 per tube. I would also suggest buying or renting the electric shear for cutting the Hardi. It works very well and there is no dust. If you cut it with a special saw blade the dust is unbelieveable and very dangerous. I thought the Hardi was very expensive. Actually it is very reasonable and you will spend almost as much on the trim.
dadflynn is offline   Reply With Quote
The Following User Says Thank You to dadflynn For This Useful Post:
tgolloshi (06-24-2010)
Old 06-24-2010, 08:14 AM   #3
I am interested to know more about priming the interior walls after they are sanded
tgolloshi is offline   Reply With Quote
Old 06-24-2010, 09:03 AM   #4
kwikfishron's Avatar
Rewards Points: 90
Here’s a good discussion on that.
http://ths.gardenweb.com/forums/load...326467884.html
kwikfishron is online now   Reply With Quote
Old 06-24-2010, 09:51 PM   #5
Registered User
Rewards Points: 4,924
Along with the colored caulking comes some touch-up paint for the rips and end cuts, make sure the install uses these to honor the warranty...
Be safe, Gary
Hardi plank - staining vs painting acdrey Building & Construction 36 03-22-2015 11:53 AM
Hardie Board Siding and Wind gordo409 Building & Construction 2 07-10-2007 07:00 AM
Painted deck - advice needed! Sallie Painting 5 03-23-2007 12:03 AM
Painted Tub With Epoxy, Didn't work.. Need your advice diyfan902 Painting 1 03-11-2007 04:55 PM
