Pre Hung Metal Fire Rated Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-07-2012, 10:46 PM   #1
gta
Pre hung metal fire rated door
I purchased a metal pre hung fire rated door for my garage that has an adjustable hollow metal frame. It is basically split frame construction as someone on the other forum pointed out.
How do you go about squaring up the door and checking for level and plumb?
It says in the manual to put shims underneath the threshold, but does not mention between the hinge jamb or the latch side jamb. I have installed pre hung wood doors before, not metal though.
It is a jeld wen pre hung fire rated door 90 minute rating.
gta is offline   Reply With Quote
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 05:45 PM
Want to use a pulley /counter weight to open metal hatch door to cellar MACrowley Building & Construction 4 02-22-2010 05:41 PM
Repair of Door with Metal Interference Weatherstrip KAdams4458 Carpentry 4 09-18-2009 08:38 PM
Pre Hung Door Issue! bmster Carpentry 8 03-11-2008 07:31 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
