Pre-Hung 30x69.5 Or 30x70 Exterior Doors? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-12-2009, 06:07 PM   #1
Question
Pre-Hung 30x69.5 or 30x70 exterior doors?
We bought a new house recently - 1927 Tudor - and the previous owner had started to finish off the basement and even installed an exterior door to the back stairs.
Unfortunately, the exterior door is starting to come apart at the bottom (cheap wood door that wasn't treated with any waterproofing sealant).
I need to replace the door, but it has odd measurements of:
height: 69.5" (could probably do 70" and remove a small strip of wood above the door
width: 30" (door)
width: 33 5/16" (door + existing frame)
depth: 1 3/4"
Any idea where to find/order a door of this size?
I can't go any wider because the door sits in the foundation of the house.
Thanks in advance,
b
bfenn is offline   Reply With Quote
Old 02-12-2009, 06:27 PM   #2
Old School
Willie T's Avatar
It's not the width.................. You're putting in a door less than 6' high?????? I don't think a half inch one way or the other is going to make a bit of difference.
Willie T
Old 02-12-2009, 07:27 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
As mentioned above your door height is only six feet, Any style and rail constructed wood door wood be out of the question. there would be no main support rails left on the door. even if you cut top and bottom. your only choice wood be a flush door. Or! have a custom door built at a price that might shock you. Steel door and plug the bottom. I cant see why you cant consult a mill shop, or a local lumber yard. BOB
Old 02-13-2009, 06:40 AM   #4
Rewards Points: 5,336
Like Bob said. There's no reason you couldn't order a door from the local lumber yard. I've ordered both wood and metal, reduced height doors that way.
Ron
Old 02-14-2009, 02:43 AM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
b, You are right. The bottom side of the door most likely was never sealed when it was installed. Door manufacturers make it a point that new doors must be sealed on all SIX sides immediately to maintain the warranty.
Here is a handy chart for Stile & Rail nomenclature:
http://www.google.com/imgres?imgurl=...&ct=image&cd=1
b, Try calling the Seattle lumber yards for leads:
http://www.google.com/search?hl=en&r...ds&btnG=Search
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-17-2009, 12:31 PM   #6
Remodeling Contractor
Hi bfenn,
Your best bet may be to utilize Frank Lumber's (The Door Store) matching service...they are located on 15th NE at about 180th. If you can take the door in to them, they can modify a new door for you that will be sized to match the one you bring in, and will have the hinges mortised in the same locations, and bored for the lockset(s). This applies if you can replace the slab only, and don't need or want to replace the jambs as well.
If you do want to replace the whole unit (jambs and slab), they can make a new prehung door for you that will fit the rough opening size that you give them.
Hope this helps, and good luck with your project!
Brian
Constructive1 is offline   Reply With Quote
Old 02-17-2009, 02:38 PM   #7
Tool Geek
PaliBob's Avatar
Good info from Constructive1
bfenn, Let us know what happens. You have a lot of folks rooting for you.
Disclaimer
& Stay Safe
.....Bob Lavery
Right hung door-to-left hung? Rodland Carpentry 5 12-24-2008 06:28 PM
Masonite pre hung doors sticking hot weather Pawl Carpentry 4 07-08-2008 04:26 PM
pre hung Masonite interior doors Pawl Carpentry 5 03-29-2008 10:52 AM
wall hung toilets warnerww Plumbing 39 05-10-2007 06:35 PM
