Pre Fab Vs. Stick Built - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2012, 06:18 AM   #1
pre fab vs. stick built
We are trying to decide which to build, either a pre-fab or stick built. Our concern is quality. Which would be better?
jorinda1 is offline   Reply With Quote
Old 09-14-2012, 08:16 AM   #2
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Shed? House? Garage?
Where are you building it? Alaska? Martha's Vineyard? A field in Omaha?
CoconutPete is offline   Reply With Quote
Old 09-14-2012, 08:25 AM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Go with a pre-built stick, I hear they are fab.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 09-14-2012, 09:39 AM   #4
pre fab vs stick
We are building in Indiana. We live in the woods. Good to build it into a partial Hill.
Old 09-14-2012, 09:47 AM   #5
Rewards Points: 13,724
It depends on the company that's building the prefab.
Not sure how they get away with it but a lot of mobil home companys are calling the double wides prefabs.
There still cheaply built. Nothing more then a trailer with a fancy name.
A real moduler home will not still have a metal frame under it when it's set on the foundation. Newer ones will have 2 X 6 walls, 3/4 plywood or Advantec sub flooring not partical board. Real new constrution windows not thin slim line windows.
Where any moduler home company fails is the crews they have come finish them out. Not once have I seen them do there jobs correctly.
Old 09-14-2012, 09:55 AM   #6
Rewards Points: 150
Andy.
Second that!
I have to speak for everyone here, but what the heck are you trying to build? A hide out? A tool shed? A ranch home? A multi-family home? A football stadium? A space station?
WHAT?!
oodssoo is offline   Reply With Quote
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 05:30 PM
Can't get any coating to stick to floor alternety Flooring 1 09-02-2011 05:50 AM
Re-Roofing: Okay to Re-Use Peel n Stick? GrillMouster Roofing/Siding 8 12-06-2009 01:55 PM
Stick Rafter not attached to bottom chord & sagging, new Trusses Robear Roofing/Siding 12 10-16-2009 04:41 PM
Stick built to truss conversion mikemc411 Building & Construction 7 09-15-2006 06:06 AM
