Old 08-31-2006, 09:46 PM   #1
Powered Auger??
I need to run a 4" drain pipe under a 5' wide sidewalk. Never done this before. What kind of tool(s) are available for this, other than a sewer spade? I picture some kind of powered auger like a horizontal post hole digger. Any such thing? What are your recommendations? Thanks
Bill46 is offline   Reply With Quote
Old 08-31-2006, 10:12 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Powered Auger??
Called a shovel, sweat and hard work, sorry, that what we do in the field, unless you take up the sidewalk.
Ron The Plumber is offline   Reply With Quote
Old 09-01-2006, 10:53 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Powered Auger??
A 5' span isn't nearly wide enough to justify renting a power drilling unit. Maybe if you were augering under a drveway, street or highway...
As Ron advised...a shovel should do for this job.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-01-2006, 04:03 PM   #4
Powered Auger??
Water Jet Right Under Sidewalk
RYANINMICHIGAN is offline   Reply With Quote
Old 09-01-2006, 07:21 PM   #5
Long-Time DIYer
Powered Auger??
Now THAT is an even better idea. Rig a hose attachment to a 6' piece of galvanized pipe OR use a pressure washer.
Way To Go, Ryan!
Mike
Old 09-02-2006, 11:44 PM   #6
Powered Auger??
Thanks, I'd thought about that but wasn't sure how fast it might be. Gues I'll be firing up the pressure washer.
Making a battery powered device work with an AC/DC adapter? FlyGuy Electrical 14 11-21-2010 08:28 PM
Gas Powered Pressure Washer handy man88 Tools 1 04-26-2008 08:41 AM
